wanted to use: Warped manifold flattening/grinding machine
Postby ATAl » Sat Jun 21, 2014 6:33 pm
Not quite sure what the machine is called, but basically the car has an exhaust leak around the turbo manifold area, either the manifold or the turbo housing flange is warped, and while I've got it all off the car I want to machine the flanges flat.
Does anyone in wellington have access to a machine that can do this? I can offer you beer or money in exchange.
ATAl
Re: wanted to use: Warped manifold flattening/grinding machi
Postby e30-323ti » Sat Jun 21, 2014 7:13 pm
Brian @ HOWAT Engineering (in NaeNae) did mine, not exactly a 'tool' you can borrow though...
292rwhp E30
Under Re-Construction
e30-323ti
Postby ATAl » Sat Jun 21, 2014 9:43 pm
Are Howat engineering open during the weekend? The main reason I'm trying to find someone to do this is because I can't get to an engineering place during normal work hours.
I should clarify a bit that I don't want to actually borrow the machine, just use it, or get someone to use it on a evening or weekend.
ATAl
Postby thegreatestben » Sat Jun 21, 2014 11:16 pm
Brian is there occasionally on weekends when I drive past. Probably working on his own stuff though
thegreatestben
Postby Stott69 » Sun Jun 22, 2014 8:01 pm
Ring them and ask if some will hang around one night so you can drop it off?
Stott69
Postby gepsk8 » Tue Jun 24, 2014 10:14 pm
Hit up grotty on forums (custom works) see what he got access to
O272754663
gepsk8
Postby ATAl » Tue Jun 24, 2014 10:41 pm
Thanks all, think I've got it sorted now. Turned out to be more than just warping...
ATAl
Return to Wellington / Lower North Island Region
