Where to get hubs drilled?
Postby FST4RD » Wed Nov 21, 2012 6:49 pm
Need to get the rear hubs on the starion drilled out from 4x114.3 to 5x114.3, same with the rotors.
Mate had it done on his one ages ago and can't remember where he got it done.
Anyone recommend me a place?
Can they do it in place?
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby Elmo » Thu Nov 22, 2012 9:10 pm
Royce Clive engineering behind Blacks fasteners at sockburn round about do mag wheel repairs etc, so I know they will be able to redrill hubs, I also know that they will need to be off the vehicle tho.
Another place is 3 way engineering on Pilkington way in sockburn also.
Elmo
Postby wde_bdy » Thu Nov 22, 2012 9:13 pm
Get whatever you do sorted out with your certifier as you will need the old holes welded up for a couple of them which is a tricky area.
Callum
wde_bdy
Postby Nu-Del » Thu Nov 22, 2012 9:23 pm
Custom Adapters?
Nu-Del
Postby FST4RD » Thu Nov 22, 2012 9:52 pm
Thanks guys. Will ring around.
You can get 4 to 5 stud adapters, however as it is starions need to have 0 offset wheels, putting an adapter on will make this worse. Plus I already have factory 5 stud front hubs to put on the car, so don't want to make the offsets different.
Whole car is going to need certing anyway, heaps of mods, this will be 1 more thing to addum the list.
FST4RD
Postby Nu-Del » Thu Nov 22, 2012 9:57 pm
FST4RD wrote:Thanks guys. Will ring around.
If you go down the adapters path give me a buzz :) have been dealing a lot with custom spacers lately so have an engineering company pumping them out for me at a good price :)
Nu-Del
Return to Christchurch / Upper South Island Region
