Wtd: Aluminium block
Postby crispy'86 » Thu Jun 13, 2013 11:31 pm
Going to make some brackets out of alloy block, looking for 20mm thick aluminium , 150mm long 50mm wide. Where's the best place to go for this in chch?? Scrap metal merchants?
crispy'86
Postby fangsport » Thu Jun 13, 2013 11:34 pm
14mm ali at 150mm X ??????mm
what's the mystery measurement. might have something here.
otherwise Ulrich or scrappy's
fangsport
Postby Bling » Fri Jun 14, 2013 12:44 am
Yeah scrappy would be first stop, though 14mm is quite thick so not sure how common it would be.
Re: Wtd: Aluminium block
Postby JZCrazy » Fri Jun 14, 2013 9:43 pm
crispy'86 wrote:Going to make some brackets out of alloy block, looking for 20mm thick aluminium , 150mm long 50mm wide. Where's the best place to go for this in chch?? Scrap metal merchants?
That is one big ass bracket. 8O
JZCrazy
Postby crispy'86 » Fri Jun 14, 2013 10:23 pm
It's going to be cut down width wise, Bit hard to explain but starting at 20mm thick for the first 10 or so mm then stepping down thickness to 11mm along the length of it
crispy'86
Return to Christchurch / Upper South Island Region
