Valve keeper removal tool
Postby GDII » Sun May 10, 2015 7:22 pm
Has anyone used one of these tools to remove valve springs with the head still on? Do they actually work?
http://m.ebay.com/itm/Lisle-36200-Magne ... 0973803598
Where in NZ can I get one? I can get one from the USA so that might be the go.
Also what is the valve spring size of a 3SGE?
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Re: Valve keeper removal tool
Postby Vertigo » Sun May 10, 2015 10:30 pm
Hammer and a socket
TVIS just kicked in, yo!
Vertigo
Postby GDII » Sun May 10, 2015 10:39 pm
Yes hammer and a socket with a magnet in it to remove is simple. What about reinstalling them? I'm going to replace the valve seals to try slow the oil consumption down.
1990 SW20 MR2
GDII
Postby Jason T » Sun May 10, 2015 10:47 pm
GDII wrote:Yes hammer and a socket with a magnet in it to remove is simple. What about reinstalling them? I'm going to replace the valve seals to try slow the oil consumption down.
Follow this guide
http://www.supraforums.com/forum/showthread.php?367794-Poormans-Valve-Stem-Seal-DIY-How-To
Reinstall with PVC tube and paper to secure collets keepers
watch the videos
Have used this methoud a couple of times it works well
Fixing Toyota's since '87
Jason T
Postby GDII » Sun May 10, 2015 11:07 pm
The paper idea looks interesting. I haven't heard of that one before.
1990 SW20 MR2
GDII
Postby 71TA22 » Tue May 19, 2015 8:57 pm
I have used this tool with good results on 2TG engines. Its very quick.
Helps to use an extension bar and socket over the tool to provide more push as old springs can be quite resistant.
Mike
71 TA22
My Car
71TA22
Postby GDII » Tue May 19, 2015 11:13 pm
I found this tool. Not so good for removing but I can use the socket with magnet method.
http://www.toolandindustrial.co.nz/shop ... oval/1490/
And valve seal removal pliers
http://www.toolandindustrial.co.nz/shop ... ight/1492/
I have removed most of the engine parts to do the valve seals and cam belt all at the same time. GEN2 3SGEs are so complicated just to remove the valve cover. And being in an MR2 is a bit more fun. It's enjoyable work though.
Still need to buy the valve tools and get an air compressor adapter to hold up the valves. That's coming in the mail, custom built too.
1990 SW20 MR2
GDII
Postby GDII » Sun May 31, 2015 11:04 am
No luck with the tools and industrial guys. 3 forms of contact and no reply. Even after ringing twice and talking to two people I've had no response. The valve collet installer would have been useless anyway. Only works for valve springs that are exposed.
I've tried the paper method with no luck. The collets keep popping out. Anyone got any ideas? I should have just ordered the one I linked first. Anyone in Wellington have this tool?
1990 SW20 MR2
GDII
Postby GDII » Sun May 31, 2015 11:33 am
Ok ignore that. Paper and some pliers works.
1990 SW20 MR2
GDII
Postby GDII » Sun Jun 07, 2015 9:18 pm
I ended up going back to using a socket, 150mm extension and a slide bar with the paper to reinstall the valve springs. Need to fold the paper over at least 6 times to get it to work.
Thanks Jason T for the link. Took me 1 hour to do the first one but did the last 5 in 50mins. Not a fun job. I'm hoping it helps with oil consumption and doesn't make it worse from a failed install.
1990 SW20 MR2
GDII
Postby cat007 » Thu Oct 29, 2015 8:32 am
If you're wanting a good quality product:
http://www.toyotool.com/PURCHASE.htm
I borrowed one a while back for my 1G - made life SO much easier!
Postby GDII » Thu Oct 29, 2015 11:34 am
A friend of mine has one, I only found out AFTER I had done this. Was a waste of time anyway as the piston rings are the problem so I replaced the engine with a better one.
1990 SW20 MR2
GDII
Users browsing this forum: Bing [Bot] and 6 guests
