Toyota Blade V6.
Re: Toyota Blade V6.
Postby flygt4 » Sat Oct 08, 2016 2:46 pm
Yep can confirm the aurion pedal dance works on these blades too.It completely transforms the acceleration in 1st gear but requires a bit of feel for the throttle without the idiot proofing to stop you leaving a cloud of smoke. Not as bad as expected though if you wind into it a little like you would in any other moderately powered 2wd car, I suspect you would still be faster to 100km with it turned off.
flygt4
Postby Al » Mon Oct 10, 2016 1:41 pm
Yep sure makes the car feel different to drive after teh pedal dance.
85 Corolla GT - 08 Blade Master G - 87 FX-GT
Al
Postby s4turn » Tue Dec 05, 2017 8:50 pm
Havent been here in a while, but thought id notify others just in case.
I got a call from Toyota today about my 08 blade master needing the passenger air bag replaced.
this is being done under Toyota as a recall
I think this might be the details here:
https://www.toyota.co.nz/about-toyota/t ... and-yaris/
s4turn
Postby Bling » Fri Dec 08, 2017 6:21 pm
Thanks for the heads up, I might look into that one day for ours.
