3sge spring loaded exhaust bolts - source/?
Postby xsspeed » Sun May 29, 2016 11:45 pm
any one got a source for spring loaded exhaust bolts? managed to shear mine - the threads were welded above the fixed nut - didnt realise until i had well yielded both
Re: 3sge spring loaded exhaust bolts - source/?
Postby Dell'Orto » Tue May 31, 2016 10:31 am
Can't pilfer some from Zebra/Pick a part?
Postby xsspeed » Tue May 31, 2016 11:15 am
could be the go, assuming they are on the non-beams 3s's aswell. Issue will be if they were all welded or someone just did this one to be 'helpful' im hoping the latter
Postby Dell'Orto » Tue May 31, 2016 4:05 pm
If its the ones I am thinking of, they are reasonably common - Altezza rear mufflers are bolted on with them, but ought to be used of many slip joint style exhausts
Postby xsspeed » Sun Jun 05, 2016 6:35 pm
cheers for pro tip brad, sourced some from zebra
Postby 1I1 » Wed Jun 08, 2016 3:08 pm
Dell'Orto wrote:If its the ones I am thinking of, they are reasonably common - Altezza rear mufflers are bolted on with them, but ought to be used of many slip joint style exhausts
A lot of late model Toyotas run them on their exhausts
TRD Clicky >>Here
1I1
