Turbo rebuild kits
Turbo rebuild kits
Postby Vertigo » Sat Nov 25, 2017 8:36 am
So, the turbo I put on started making some noises I didnt like, and there seemed to be some minute shaft play, and I dont know its history, so better to just rebuild it now that everything works.
Where should I source good quality rebuild kits from? This is an EVO TD05HR.
TVIS just kicked in, yo!
Vertigo
Re: Turbo rebuild kits
Postby Vertigo » Sat Nov 25, 2017 6:41 pm
Ended up going with this.
http://shop.mambatek.com/product.sc;jse ... egoryId=19
Has an uprated thrust plate, and more likely to be quality than something from Trademe or Ebay.
The other option was Mitsi OEM parts, but i can imagine they would be rather pricey.
Vertigo
Postby GDII » Sun Nov 26, 2017 9:08 am
Just curious, how well does steel work as a bearing? Doesn't it start galling? Or is that only an issue where it's not lubricated properly? I see the stock and Stage II are brass.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby Dell'Orto » Sun Nov 26, 2017 9:31 pm
I actually thought the Mitsi kits weren't too spendy. but it was a while back when I last looked
Postby RS13 » Tue Nov 28, 2017 7:31 pm
FWIW, some radial play in the shaft is perfectly normal. Axial, not so much.
RS13
Postby Vertigo » Fri Dec 01, 2017 10:10 am
Based on the questioning of steel thrust bearing here and elsewhere, Ive switched out to the stage 2 kit with brass thrust bearing with improved oil ports.
Vertigo
Postby GDII » Wed Dec 06, 2017 9:02 pm
Vertigo wrote:Based on the questioning of steel thrust bearing here and elsewhere, Ive switched out to the stage 2 kit with brass thrust bearing with improved oil ports.
My question was put forward because I don't know. They wouldn't make it from steel if it didn't work but based on discussions with people who know more about metal types than me I thought I'd ask.
1990 SW20 MR2
GDII
Postby Vertigo » Tue Jan 30, 2018 7:26 pm
Its ok, it was more than your question that prompted me to do so :P From what I can deduce, the steel bearings are great, so long as lubrication is perfect, but fail easily if oiling is interrupted in any way. Would rather not risk it.
Vertigo
Postby GDII » Thu Feb 01, 2018 2:07 pm
All good. I'm glad you've got it all working now.
1990 SW20 MR2
GDII
