After a bit of aluminum tube offcut
Postby 1I1 » Tue Apr 14, 2015 3:44 pm
On the hunt for a small off cut of (30-50mm length) aluminum tube with an OD of preferably 1.5". Can make do if its a bit bigger diameter. Thickness somewhere around 2mm?
Hopefully someone might have some scrap pipe just lying around.
TRD Clicky >>Here
1I1
Re: After a bit of aluminum tube offcut
Postby DeeCee » Thu Apr 23, 2015 6:16 pm
You still lookin Mark? Can't remember what Al pipe dia I have in the garage, but I ended up buying 3m for a .3m BOV recirculation haha.
Will check for you if I remember when I get home
GT Four Adovansu
DeeCee
Postby 1I1 » Thu Apr 23, 2015 9:03 pm
Cheers man. I got a piece thats a fraction big, just need to chop/weld it and it'll do the trick
TRD Clicky >>Here
1I1
Return to Palmerston North / Central North Island Region
Users browsing this forum: Google [Bot] and 1 guest
