PLEASE READ: tech info/FAQ/how tos
Before asking a question on the board you will find many answers here.
Postby Santa'sBoostinSleigh » Mon Oct 23, 2006 5:13 pm
We had a bit of a moderator meeting at the Naki Mega(Mini)Meet around the Tech, FAQ and General sections.
We would like to call on you smart cookies out there to submit How-To's and other tech info so that we can compile good sections
we dont want "my mates brothers cousin brought it off this guy on trademe and he said this", we want hard working facts, backed up by a this doesnt work etc
this info will be dynamic and we can update and change it as needed
this has come about because some of the sections are full of utter rubbish and the same thing is covered 50million times!
spanks a million
Andrew
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby crnkin » Mon Oct 23, 2006 5:48 pm
The one thing i do know is 4age rods, so could post this for ya's. Comes in helpful as not alot of people have pulled apart every version of 4age, which i have had the er-hm, 'pleasure' of doing (mostly due to blowing up):
"There are 6 types of rods, i have had a set of all but one (early mr2 ones)
1. early mr2 38mm big, 18mm gudgeon
2. bluetop, 40mm big, 18mm gudgeon
3. redtop tvis, 42mm big, 20mm gudgeon, lightened
4. redtop non tvis, 42mm big, 20mm gudgeon, full cast
5. Silver top, 42mm big, 20mm gudgeon, similar build to bluetop
6. Blacktop, 42mm big, 20mm gudgeon, tiny tiny tiny lightweight ones.
ae101 map and ae92 map gze run silvertop rods
ae92 early and mr2 run retop non tvis"
yeah? nah?
deaf_homo "currrently yes"
crnkin
Postby Dell'Orto » Mon Oct 23, 2006 6:37 pm
Wouldnt happen to have photos of them would you Chris?
Postby Silent Knight » Mon Oct 23, 2006 7:50 pm
I made a step by step manual conversion guide with photos when I did the conversion on my Supra.
The process is basically the same for most RWD cars I'd suspect...
http://mk3supra.co.nz/Technical/ManualConversion.htm
Silent Knight
Postby Pies » Mon Oct 23, 2006 8:23 pm
i can offer several "how to's" on how to destroy a 4age ;)
Current Rides:
Pies
Postby Dirtbag » Mon Oct 23, 2006 8:37 pm
As I posted a week ago in my thread, different techniques to replace gearbox oil, locations of filler and drain holes on popular boxes etc would help alot of people out I would think. I felt kind of stupid asking where the holes were, so a place where the locations are obviously stated might make some people stop feeling so stupid!
AE101 GT-APEX Superstrut
My profile!
Dirtbag
Postby crnkin » Mon Oct 23, 2006 8:45 pm
Mmm, Boost wrote:Wouldnt happen to have photos of them would you Chris?
hmmm.... on my pc at home i have the redtops, silvertops, redtop tvis, and bluetop, however the mr2 ones were super weird, my friend had the block, had 38mm crankshaft with 8 flywheel bolts! And blacktop well weve all seen, i can post up in a few days
crnkin
Postby Mr Revhead » Tue Oct 24, 2006 9:55 pm
id like to see proff of the 38mm crank and rods please.
itll be the first iv ever heard of it.
also not all smallport 4age/map ae92 gze rods are the same as the silvertop ones.
they change from the early big ones is later than the small port head change.
what should be happening is a clean up of the FAQ section, as in organise it, put things in sections so ppl know where to look. at the mo is a fcuking mess.
then when decent stuff is posted in tech, it gets FAQd. often thats not being done as well
Postby IH8TEC » Tue Oct 24, 2006 11:01 pm
my ae92 bigport 4agze rods obviously wider thicker and beefier than silvertop ones on the right.
Postby crnkin » Tue Oct 24, 2006 11:31 pm
Mr Revhead wrote:id like to see proff of the 38mm crank and rods please.
as above, ive only seen one case, no proof, so i guess it didnt happen
Mr Revhead wrote:also not all smallport/afm ae92 gze rods are the same as the silvertop ones.
thats exactly what I said!!!
Mr Revhead wrote:they change from the early big ones is later than the small port head change.
That makes no sense. Silvertop rods in silver top, and in map gze.
smallport gze have silvertop rods, smallport NON gze have early gze rods.
I wish people would read what i wrote instead of writing the same shhite over and over again. Its because of you that we need a FAQ section! So that the crap gets lost!
crnkin
Postby Mr Revhead » Wed Oct 25, 2006 9:23 am
i made a typo, which i have now corrected:
they change from the early big ones to the silvertop type is later than the small port head change
so yes, i agree a good FAQ is needed to weed out the BS. and man is there HEAPS on the net about the 4age4agze, let alone other engines/cars :?
Postby Mr Revhead » Tue Dec 05, 2006 11:35 am
the rule of thumb to remember about 4age/4agze conrods is they are exactly the same.
eg a 4agze built in march 1989 has the same rods as a 4age built at the same time. and a 4agze from dec 1991 has the same rods as a dec 1991 4age.
the small port head change is at a different time than the rod change.
so small ports have both the large and 20v type small rods.
so:
crnkin wrote:smallport gze have silvertop rods, smallport NON gze have early gze rods.
that line is not correct
Return to FAQ - Frequently Asked Questions
