www.drivenperformance.co.nz - Performance Parts for Sale
Postby cat007 » Tue Sep 22, 2009 9:29 am
Hey
In regards to your Oil catch can M-spec 2L w/breather filter:
Does this have any chambers inside it to help catch the airborne oil particles?
Postby TWSTD » Tue Sep 22, 2009 10:45 am
cat007 wrote:Hey
No - it doesnt need them. Its not an air oil separator or a water separator. You can add steel wool to the inside if you want, but once again its not really necessary to condense the oil from vapour.
Click here!
TWSTD
Postby cat007 » Wed Sep 30, 2009 10:08 am
Thanks for the catch can :)
Do you have any Redline Shockproof Blue gearbox oil?
Postby TWSTD » Wed Sep 30, 2009 10:22 am
cat007 wrote:Thanks for the catch can :)
Hi :-)
We dont have it in stock but can probably get it in for you. Please send through an email to sales@drivenperformance.co.nz with your inquiry.
Thanks!
Click here!
TWSTD
Postby matt dunn » Fri Oct 02, 2009 10:37 pm
Looking for some large injectors, have sent you an email.
matt
Postby TWSTD » Fri Oct 02, 2009 11:02 pm
matt dunn wrote:Looking for some large injectors, have sent you an email.
matt
Really? Havnt received anything?
Click here!
TWSTD
Postby matt dunn » Fri Oct 02, 2009 11:16 pm
Lost in cyberspace?
After something around 1000cc and top feed.
Email should be there, if it's not there in the morning let me know and i'll re-send it.
Postby TWSTD » Mon Oct 12, 2009 7:35 pm
New products available in August:
Hydraulic Handbrake - Drift / Rally / Autocross - $239.99+
DPR 0.58 / 0.50 quick spool T3T4 - $529.99+
Twin filter intake kit - $79.99+
New DPR wheel spacers and hub adaptors - a range of fitments available from: - $149.99+ per pair. This particular example is the 6 to 5 stud adaptors 6x139.7- 5x114.3 ($179.99+ per pair)
DPR 1JZGTE Twin Turbo T25 manifold set - $399.99+
DPR Mazda MX5 1800cc turbo manifold - $339.99+
DPR Pulsar GTiR T25 / T28 manifold - $399.99+
DPR T3T4 5-bolt dump pipe - $169.99+
DPR Dump pipe SR20 3" high flow - $169.99+
DPR Dump pipe RB20 / RB25 3" high flow - $189.99+
DPR Dump pipe 4EFTE starlet EP82 / EP91 - $159.99+
DPR front pipe EVO 1-3 - $239.99+
DPR front pipe EVO 7-8 - $199.99+
DPR front pipe WRX / STI 02-07 - $239.99+
DPR up pipe WRX / STI 02-07 - $129.99+
Stainless Muffler 2.25" w/ 4" tip - $129.99+
We have also recently picked up the NZ agency for Perfect Power so can now offer the entire range of Perfect Power ECUs. They offer everything from Wideband kits to Piggybacks to stand alone ECUs. Not all items are listed on our website but we can supply any item they make. Here are some examples:
Perfect Power SMT8L piggyback - $579.99+
Perfect Power SMT8 piggyback - $699.99+
Perfect Power TF-10 turbo fueler - $529.99+
Perfect Power XMS4A-4AKT stand alone ECU kit - $999.99+
Perfect Power XMS4C8AKT stand alone ECU kit (top of the line!) - $1449.99+
Click here!
TWSTD
Postby TWSTD » Sun Oct 25, 2009 7:23 pm
And more new items (limited stock):
Starlet intercooler kit - $479.99+
7MGTE supra dump pipe - $279.99+
Fan controller / Oil water temp display - $139.99+
S14/15/R33 camber arms - $169.99+
Exhaust system WRX GC8 - $499.99+
Click here!
TWSTD
Postby EssDub » Mon Nov 30, 2009 12:19 pm
Any chance of some of those SW20 MR2 Turbo exhaust systems?
1992 SW20 MR2 GT-S Turbo
Previous Rides: Mazda 323, Toyota Levin BZ-G, 1992 SW20 MR2, 1994 Gen3 SW20 MR2 T-Bar
EssDub
Postby TWSTD » Mon Nov 30, 2009 8:31 pm
EssDub wrote:Any chance of some of those SW20 MR2 Turbo exhaust systems?
Yes we can supply one - flick us an email :-)
Cheers!
Click here!
TWSTD
Postby deaf_rattle » Mon Nov 30, 2009 8:37 pm
Hey Al
Are you able to tell me how many bottles of water wetter one would need for a typical coolant system?
Postby TWSTD » Mon Nov 30, 2009 8:41 pm
deaf_rattle wrote:Hey Al
Unsure sorry mate! does it not give a dilution suggestion on the redline website?
Click here!
TWSTD
Postby strx7 » Mon Nov 30, 2009 9:16 pm
Pretty sure the bottle recomends half the bottle for an average size system.
Postby TWSTD » Fri Dec 04, 2009 6:52 am
And goodies just landed in time for X-mas:
Short Shifters - from $79.99+
New models incl: AE86, Altezza, FC and FD RX7, Mazda 3, E30, 36, 46 BMW and more!
DPR Cam gears - SALE $179.99+
Available for: 3SGTE, 4AGE, 1J/2J, CA18, SR20, RB20/5/6, BP B6 Mazda, 4G63 EVO 4-9, 4G92/3.
4AGE 16v RWD turbo kit - $899.99+
HICAS lock bars - Most nissan models - $119.99+ (2 models availalbe suit S13, S14, S14, R32, R33, A31 etc)
Toe Arms S13 - $119.99+
Toe Arms S14 S15 - $119.99+
Traction Rods S13,14,15, R33,34, A31, Z32 - $119.99+
Front Castor Arms S13, S14, S15 - $119.99+ (2 fitments)
Front camber arms R32 Z32 - $199.99+
Nissan solid subframe kit - $119.99+
WRX GC GD Toe arms - $119.99+
Click here!
TWSTD
Postby Dell'Orto » Fri Dec 11, 2009 6:51 pm
What size do you need Kenny? I can get them for you, they're cheap enough
Postby Akane » Fri Dec 11, 2009 10:50 pm
4mm OD on pipe. It's off the TB evap thingee
Postby 4agtepwr » Thu Mar 25, 2010 12:27 am
Hi im keen on trying one of your water to air intercoolers? have you had any reviews of them? do you have them in stock?
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
4agtepwr
Postby TWSTD » Thu Mar 25, 2010 6:33 am
Yes we have sold many of these for various performance applications (incl 400HP jet skiis!). Yes we have them in stock.
Just place your order via our online store, and make note that you are a TS member in the comments box - we will then apply your discount once the order comes through and you will recieve an email with account details and the new discounted total :-)
Click here!
TWSTD
Postby AE92-5ONIC » Sat Jul 31, 2010 12:45 am
Gah -.- I read that TS members get discounts just after I bought my cam gears. Nice range of parts in your online catalogue, was impressed.
AE92-5ONIC
Return to Toyspeed Sponsors
