Moroso 4age baffled Race Sump
Postby Bazda » Fri Jan 11, 2013 8:25 am
MRP Moroso 4age Baffled Sump
MRP has been working with Moroso on a custom 4age baffled sump to suit all types of racing conditions.
Application: 4age/7age RWD & FWD. Both early (16v) and late (20v) model sump pattern designs
Material: Steel Zinc Plated
Baffles: Internal dynamic trap doors
Volume: Extra 1L
Ports: Oil Temp, Turbo Drain, Drain plug, Head drain
The sump features a bolt in windage tray, so you can remove the OEM tray which makes installation much simpler.
$730 inc GST
Postby DeeCee » Fri Jan 11, 2013 8:34 am
As I'm not a 4AGE owner, how is turbo oil return feed handled on a 4AGTE? Is it returned to sump like gen3 3S? If so, will you build in provision for oil feed return on the moroso sump?
GT Four Adovansu
DeeCee
Postby Bazda » Fri Jan 11, 2013 8:59 am
DeeCee wrote:As I'm not a 4AGE owner, how is turbo oil return feed handled on a 4AGTE? Is it returned to sump like gen3 3S? If so, will you build in provision for oil feed return on the moroso sump?
Will def have a fitting on there for Turbo oil returns. This drawing is just a first quick revision.
Postby NOLAW » Fri Jan 11, 2013 9:57 am
i could be interested baz, already having issues with my steering arm hitting on the cast peice of the sump on my 7a at full lock so just need to check that it would clear this sump, have you got dimensions?
NOLAW
Postby Bazda » Fri Jan 11, 2013 11:04 am
NOLAW wrote:i could be interested baz, already having issues with my steering arm hitting on the cast peice of the sump on my 7a at full lock so just need to check that it would clear this sump, have you got dimensions?
This wont stick out the front like the 7a sumps so it should clear.
Postby Rob_GTZ » Fri Jan 11, 2013 11:31 am
Very interested, put me down for one.
Rob_GTZ
Postby stolic » Fri Jan 11, 2013 2:37 pm
I think he means the steering arm is hitting the upper sump pan infront of the gearbox, not the more common swaybar issue that the front can cause...
in any case more rack n pinion would solve this NOLAW :lol: if it's hitting the part that supports the bottom of the bellhousing, you could possibly get away with cutting it off and using t50 style support brackets maybe?
Barry : Keen to see how this turns out.. may be tempted to add it to my growing list of MRP goodness 8)
ImageTA22-build - TA22-blah
I envy those with little interest in cars, for they have money and spare time.
stolic
Postby 1I1 » Fri Jan 11, 2013 2:59 pm
Hey Barry as per FB, showing interest. So long as it clears AC stuff?
TRD Clicky >>Here
1I1
Postby Bazda » Fri Jan 11, 2013 3:13 pm
1I1 wrote:Hey Barry as per FB, showing interest. So long as it clears AC stuff?
Yep clears and added
Postby vr4boy » Sat Jan 12, 2013 8:35 am
Interested to Barry
1995 ae101 levin st 20v
vr4boy
Postby Bazda » Tue Aug 20, 2013 11:33 am
Update, sumps are being zinc plated! then shipping to us
Re: Moroso 4age baffled Race Sump
Postby Bazda » Fri Jul 25, 2014 12:37 pm
Bump
Plenty of stock, also have dry sump versions as well.
Return to Toyspeed Sponsors
