Extreme Clutch Kits - Street to Race
Postby Bazda » Thu Nov 13, 2014 1:50 pm
We can now offer oem fitment Extreme clutch kits.
Normally we build Twinplate Tilton clutch kits to suit anything, but we get the few guys who are just after a mild upgrade or a replacement clutch.
http://www.xtremeclutch.com.au/en/
Example pricing - Stage 1 kit HD 4age 212mm $395+gst
http://www.xtremeclutch.com.au/en/produ ... ch/stage-1
The stage 1 clutch kit uses an upgraded pressure plate with increased clamping pressure, combined with an organic friction disc. Stage 1 delivers substantial increases in performance and power holding capability whilst retaining near factory type driveability, and is designed primarily for high performance road going vehicles.
http://www.xtremeclutch.com.au/en/produ ... ch/stage-2
The stage two clutch uses an upgraded pressure plate combined with a ceramic friction disc in either sprung or cushioned configurations. The stage two clutch range is designed for road and track going vehicles that require a higher torque capacity and temperature tolerance, and faster engagement. Clutch engagement is more aggressive than stage 1, so it is not recommended for daily driven vehicles.
Return to Toyspeed Sponsors
Fatal: Not able to open ./cache/data_global.php
