Rate my spark plugs...
Postby Technohedge » Sun Sep 09, 2018 5:32 pm
From Caldina GTT thats not been boosting like it should for a while now. Keep meaning to get to the bottom of it.
Pressure gauge reads normal boost pressure, but it smells a lot of unburnt fuel so im wondering if its rich?
seems a fair bit of carbon on the plugs?
Image[/url]
Left plug is from cylinder nearest river
Technohedge
Re: Rate my spark plugs...
Postby Dell'Orto » Sun Sep 09, 2018 10:05 pm
If anything, the centre two are lean.
Postby 85AW20v » Tue Sep 25, 2018 6:36 pm
Or not firing properly hence the unburnt fuel smell.....
See ya
Simon
85 MR2 20v
85AW20v
Postby Mr Revhead » Tue Sep 25, 2018 7:18 pm
If not firing properly they will be wet and dirty.
Postby Technohedge » Tue Sep 25, 2018 10:18 pm
Hmmm its been bugging me for ages now, I have checked the resistance on all the coil packs and they seem to be consistent. Seems to be getting manifold pressure from the boost gauge reading (although Im unsure if its getting up to pressure as quickly as before, hard to tell from looking at a gauge).
Plugs arent that old either
Technohedge
Postby Dell'Orto » Tue Sep 25, 2018 10:51 pm
Have the injectors tested perhaps?
Postby Technohedge » Wed Sep 26, 2018 8:48 am
Yea I haven't tried the injectors. How does one test these?
Technohedge
Postby Bling » Wed Sep 26, 2018 7:57 pm
You take them to someone that can test them. Matt Dunn on here used to do it I think, likely still does.
Fatal: Not able to open ./cache/data_global.php
