Bad miss under acceleration 2002 corolla
Postby RAZA » Thu Jun 13, 2019 8:30 am
Hi team,
I have a 2002 corolla (e120?) With the 1.5L engine.
It has developed a fairly bad miss under acceleration between 1000 & 3000rpm. It idles fine, and once past 3000 it is fine.
It improves once the car is up to temp, but It's particularly bad for the first 5 minutes after a warm start.
Google and my guess agree there are a few possible causes.
- afm
- o2 sensor
- fuel supply (pump/pressure regulator etc?)
-plugs etc
Rather than start replacing these 1 by 1 and inevitably find out the problem is the last thing I replace, does anyone have any suggestions on how to isolate the problem?
Tia
Currently driving:
BMW 135i M
RAZA
Re: Bad miss under acceleration 2002 corolla
Postby GDII » Thu Jun 13, 2019 6:55 pm
Coils can give up on these engines. I assume it's the 1NZFE based on the 1.5litre capacity.
Spark plugs are good to just replace anyway. You can pick between the 5 types of DENSO or NGK
http://www.globaldenso.com/cgi-bin/glob ... ion=search
https://www.ngk.com/product.aspx?zpid=9326
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Postby xsspeed » Sat Jun 15, 2019 11:38 am
Sounds symptomatic of failing coil(s)
Are these coil on plug?
Postby RAZA » Mon Jun 17, 2019 4:27 pm
Thanks for the replies. It is the 1nzfe.
Any suggestions on how to check the coil packs? unplugging them one at a time while at idle doesn't tell me anything as it runs fine at idle. Am trying to avoid buying new ones then finding the fault lies elsewhere.
Currently driving:
BMW 135i M
RAZA
Postby matt dunn » Mon Jun 17, 2019 11:52 pm
Going from your explanation it really sounds like a failing coil.
They are hard to tell which one though.
Sometimes it is just as easy to get one, fit it to cyl 1 and try it.
If not fixed try cyl 2, then 3 then 4 etc.
OR see if there is a fault code in the system,
possibly not though from a coil fault.
Postby RAZA » Tue Jun 18, 2019 8:18 am
Ok cheers will get hold of a coil and give that a go.
Currently driving:
BMW 135i M
RAZA
Postby Flannelman » Fri Aug 16, 2019 6:28 pm
Plug gap.
Got a BA Falcon that had the same issue. Stutter when cold, got better when hot. Guy replaced coils and was still there.
Gap was 1.7mm!
The Flannel, formally known as Affroman
Flannelman
formerly known as Affroman
Postby matt dunn » Fri Aug 16, 2019 11:36 pm
Flannelman wrote:Plug gap.
Gap was 1.7mm!
Thats a common issue on the Falcons, as the factory gap on them in either 1.3 or 1.5mm from memory,
and the coils have a weak arse spark anyway.
We always put in plugs with a more standard gap than spec on them.
