Shifter Cables
Shifter Cables
Postby Grrrrrrr! » Thu Jul 10, 2014 6:06 pm
Does anyone in Auckland have some corolla shifter cables with shagged bushes lying around? Trying to see if the same spherical bearing solution that i've found for the MR2 will work for the corolla, or other common FWD/4wd toyotas. From what I've seen Toyota doesn't sell replacement bushes, they make you buy a whole new cable ($$$), and the turned brass bushings others sell don't allow for movement due to the cables not being perfectly square to the pin.
Shagged bushes, the hole in the right one should be round:
Replacement bearings fitted in the cables:
So if someone has a set of shifter cables from an AExxx/EPxx/STxxx out of the car in Auckland and wouldn't mind me coming over and doing some measuring up of the cables (should take all of 10mins) drop me a PM. Or if you have calipers you could measure them up for me. Just need the ID and thickness of the steel ring at the end of the shifter cable (need to push the bushes out to measure) , and the thickness and ID of the bushes (if the bushes are flogged out like above a measurement of the pin on the gearbox would work, i'm hoping its 8mm dia, and bushes are 13mm thick)
Grrrrrrr!
Re: Shifter Cables
Postby ~SlideWays~ » Fri Jul 11, 2014 4:01 pm
I need to do this on my AE92 GTZ ones, they must be stuffed. But I'm in Wellington.
Out of interest, is there more play in those than a metal bearing?
~SlideWays~
Re: Shifter Cables
Postby Grrrrrrr! » Fri Jul 11, 2014 4:07 pm
You can't feel any play in them. Being plastic i'm hoping they should last forever and they wont rust, and do not need lubrication. Will be installing them in the mr2 tomorrow if weather and time permit, and doing an autocross on Sunday. Only concern I have is temperatures. Should be fine on normal road duties, but heatsoak off a hot turbo after a track session might not be so great.
Grrrrrrr!
Re: Shifter Cables
Postby magweal » Mon Aug 04, 2014 9:43 pm
How did you go with these, I'm looking at some thing for my 101
98 BZ-T rola SMUGLN V1(RIP)
97 NZ new GL rola now with BZ transfer 80%
magweal
Re: Shifter Cables
Postby Grrrrrrr! » Mon Aug 04, 2014 9:50 pm
heh, still sitting around waiting for the trifecta of a warmish day, me being available and motivated, and the garage not being full of pissheads/pushrod v8s or screaming kids.. Should happen by xmas.
Grrrrrrr!
Re: Shifter Cables
Postby mr_jas » Mon Aug 25, 2014 10:49 pm
skateboard wheel bearing fit perfectly and have a great feel with no resistance.
they did for mr2, celica and caldina ive done anyway
mr_jas
Re: Shifter Cables
Postby Lurkin » Wed Aug 27, 2014 9:16 pm
PM Kiwi-Corolla - hes just done this....
Past casualties
1986 4age liftback (sold)
1985 4age aw11 (well crunched)
1993 ae101 gt apex levin (sold)
Lurkin
Re: Shifter Cables
Postby Kiwi-Corolla » Wed Aug 27, 2014 9:43 pm
Yeah I just did this today. Bearing shops here wanted around $30 each for a spherical bearing and none of them offered the PTFE coated (teflon) type, so would require periodic lubing. I ended up importing 10 from overseas, so if you want a pair just hit me up. Can do two for $40.
Kiwi-Corolla
Re: Shifter Cables
Postby Al » Wed Aug 27, 2014 10:07 pm
Seen too many snapped MR2 shifter cables after people used skateboard bearings in them. They don't allow the cable to twist like it does with the rubber in the OEM bushing.
85 Corolla GT - 08 Blade Master G - 87 FX-GT
Al
Re: Shifter Cables
Postby Octane13b » Fri Aug 29, 2014 4:22 pm
^^ This.
Just pulled some ABEC-5 bearings out of mine. Explains so much.
Octane13b
Re: Shifter Cables
Postby kim0663 » Sun Aug 31, 2014 11:50 am
Kiwi-Corolla wrote:Yeah I just did this today. Bearing shops here wanted around $30 each for a spherical bearing and none of them offered the PTFE coated (teflon) type, so would require periodic lubing. I ended up importing 10 from overseas, so if you want a pair just hit me up. Can do two for $40.
those are ptfe lined?
Mr2 GT-S
330ci M
kim0663
Re: Shifter Cables
Postby Kiwi-Corolla » Sun Aug 31, 2014 1:12 pm
kim0663 wrote:those are ptfe lined?
Yep.
Kiwi-Corolla
Re: Shifter Cables
Postby Sinturion » Fri Dec 05, 2014 2:41 pm
Hey, you wouldn't happen to still have a couple of these lying around? I'm after some for my mr2.
cheers,
Alex
Sinturion
Re: Shifter Cables
Postby Kiwi-Corolla » Sun Dec 07, 2014 6:34 pm
Sinturion wrote:Hey, you wouldn't happen to still have a couple of these lying around? I'm after some for my mr2.
cheers,
Alex
Hey Alex, yeah I still have some available. Flick me through a PM and I'll provide you with the payment details :)
Kiwi-Corolla
Re: Shifter Cables
Postby DuddleyOS » Tue Apr 04, 2017 9:23 pm
Apologies for bringing up such an old thread. I have the same shagged shifter cable bushes that Grrrrrrr! had and was wondering where you guys got the spherical bearings from and what sizes?
DuddleyOS
Fatal: Not able to open ./cache/data_global.php
