Toyota HID issues - Light Fade
Postby ptrain » Tue Apr 11, 2017 12:52 pm
Hi all,
Have any of you encountered intermittent lights with the Toyota HIDs? I've noticed occasionally my Blades dipped beam is off on one side, after witching the lights on and off a again, all is fine. It seems to be intermittent.
I've read on other forums that the ballast packs are a known fault with prius' in America. Am I finding the same issue? I'm going to swap the bulbs over tonight and see if the problems moves with the bulb. But the description sounds exactly like
The ballasts are at the bottom of the light units... any tips on getting the lights off the car without damaging stuff? I can get ballasts for $40 from our Chinese friends at aliexpress... worth the gamble? They are about $500 from amayama + shipping. I've not been able to get through to any of the Auckland Toyota branches today..
ptrain
Re: Toyota HID issues - Light Fade
Postby sergei » Tue Apr 11, 2017 9:01 pm
Most likely it is the bulb...
Users browsing this forum: Google [Bot] and 3 guests
