Tacho wiring
Tacho wiring
Postby mega4a » Sat Aug 05, 2017 6:10 pm
Hi guys manage to get my car going now. Just wiring up some outputs for my g4 storm can anybody tell me the dash cluster wiring for a ae101 4age 20v blacktop I need to wire up my tacho/rev counter and my engine check light but can't find much information on it. Any help would be much appreciated cheers
DAILY DRIVEN.
230HP ATFW AE100 WAGON 4AFTE MEGASQUIRT.
1999 Toyota Corolla BZ Touring wagon 4age 20v bt.
1996 Toyota Truneo 5AFE
mega4a
Re: Tacho wiring
Postby GDII » Sun Aug 06, 2017 8:41 am
If it's anything like my MR2 of which most 90s Toyota are then the Tacho signal wire from the stock coil will be black and the check engine light with will be green with white stripe.
Check engine light wire should be easy to find if you take the cluster out and follow it on the circuit board behind it. Tacho should be similar as it will connect to the dial through 1 of the 3 mounting screws.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
