JZX81 INFO
JZX81 INFO
Postby BlakeNZ » Mon Aug 21, 2017 11:22 pm
Any JZX fans out there? A few questions...
Firstly, i always thought the jzx81 GT had an electronic dash, but recently i saw a youtube vid of a turbo hardtop that had anolog speedo and rev dials in its cluster. it was a '91 or '92 model from memory. Does anyone know what came with what?
Also, i like the sedans, rather than the hardtops. Is the sedan only available in the mark II, or were they also offered in the cresta and chaser? (all the cresta and chasers i see ,seem to be hard tops).
Lastly, do you know of anyone with a genuine 1jzgte jzx81 GT sedan(same body shape as MX83 cressida), as i'd like to view one in person?
cheers for any help you can give.
JZZ30 soarer 1JZGTE 11.5sec@122mph(stock turbos,E85)
BlakeNZ
Re: JZX81 INFO
Postby GDII » Tue Aug 22, 2017 12:27 pm
The electronic dash from a quick look came in the 1990/08 - 1993/02 JZX81 MARK II with a body code of JZX81-AEPQF. There are more out there such as the Cresta and Chaser that used the same electronic dash with differing years.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Re: JZX81 INFO
Postby Jonno2002 » Mon Nov 13, 2017 1:05 pm
pretty much all you need to know is on a few handy sites i use:
http://jp-carparts.com/toyota/carlist.php?maker=toyota
http://www.toyodiy.com/
http://www.japaneseusedcars.com/car_spe ... alogue.htm
have a GOOD look through them and all your questions are answered 8)
the sedan/hardtop thing is markII specific as the markII comes both sedan and hardtop whereas the cresta is just a sedan but its own unique shape, and the chaser is a hardtop, interestingly enough tho the chaser and the markII hardtop share the same body lines so the front ends can be swapped without any modification they just bolt on.
the jzx81 markII gt only came as a hardtop, and had both digi and analogue dash, also the chaser and cresta came out jzx81 gt too i guess thats your sedan right there
i have a jzx81 gt if your interested in more info about them
Jonno2002
