AE101 Caster Adjustment
Postby Lucky13 » Wed Jun 27, 2018 10:56 am
Hi all
After a couple of dings over the years the caster is now out on my AE101 Trueno track car (Mcpherson strut). This causes it to pull to one side... somewhat unnerving when flying into a corner at excessive speed!
Obviously there is not caster adjustment as standard so my question is, what can I do about this? Is there some form of adjustable control arm that anyone knows of or any other possible solution you guys can suggest?
Lucky13
Re: AE101 Caster Adjustment
Postby 1I1 » Wed Jun 27, 2018 5:28 pm
Super pro do a caster correction rear bush for the AE111 - what about converting to those style arms with a vertical bolt?
https://imageapi.partsdb.com.au/api/Ima ... 4rGq7XA%3D
TRD Clicky >>Here
1I1
Postby Lucky13 » Wed Jun 27, 2018 5:46 pm
Possibly but I was hoping for a more simple solution!
Lucky13
Postby 85AW20v » Wed Jun 27, 2018 6:20 pm
It might need to go on a chassis straightener.....
See ya
Simon
85 MR2 20v
85AW20v
