Side exit exhaust
Do it?
No
9
16%
Yes
40
71%
Akane's grip > your grip
7
13%
Total votes : 56
Side exit exhaust
Postby iOnic » Thu Oct 14, 2010 4:42 pm
Been toying with the idea since I can't have the exhaust out the back for various reasons. Thought I might cut up some scrap bits of steel today and see what I think of it.
If I do go for it, the pipes will be properly slash cut stainless with a stainless heatshield of some description riveted to the skirt. The car may also be washed. Possibly.
Thoughts?
Postby touge_ae101 » Thu Oct 14, 2010 4:45 pm
would be awesome to see! flames out the side would be epic cool! is the seperate pipe for a possible screamer?
touge_ae101
Postby 1I1 » Thu Oct 14, 2010 4:45 pm
Be good to see a decent side photo but going off the photo above it looks tough! Two wastegate pipes?
TRD Clicky >>Here
1I1
Postby iOnic » Thu Oct 14, 2010 4:46 pm
Yep 2 wastegate dumps. One off each wastegate (twin entry turbine) and a single 3" turbo dump. I'll try and get a better picture of it at some point over the weekend
Postby iamawesome » Thu Oct 14, 2010 4:53 pm
side pipes are about as cool as it gets.
iamawesome
Postby rx7guy » Thu Oct 14, 2010 5:03 pm
do it. hard
The torque band is wide and the road is narrow
rx7guy
Postby Emz » Thu Oct 14, 2010 5:06 pm
+1 for do it
'97 Supra RZ - Click Here! | Discussion thread - Click Here
Emz
Miss Supra Princess
Postby Bling » Thu Oct 14, 2010 5:07 pm
Voted for do it.
Can't merge the wastes into the main? Tidier imo
Postby iOnic » Thu Oct 14, 2010 5:28 pm
Haven't really looked into it tbh :lol: But merging them into the downpipe just after the turbine should make life a little easier for me and possibly quieten the thing down a tiny, insignificant bit
Postby touge_ae101 » Thu Oct 14, 2010 6:55 pm
might pay to look at fabricating the rear bit of the sideskirt out of stainless to try stop everything from melting. would look pretty cool too IMO. looks pretty simple to copy the profile of the side skirt and weld up.
touge_ae101
Postby iOnic » Thu Oct 14, 2010 7:57 pm
I'll be making a stainless steel heat shield on both the outside and inside of the sideskirt. I don't really wanna do anything too drastic because I'm sorta expecting the sideskirts to get smashed up/damaged fairly often with the car being so low so it's easier to repair them if I keep them mostly fibreglass
Postby d1 mule » Thu Oct 14, 2010 8:16 pm
there are rules governing the distance the exhaust has to exti behind the rear most door, i think itssomewhere from 200-300mm from memory, which may be hard on the mr2 but apart from that DO IT!!!!!!!!!!!!
d1 mule
Postby Leon » Thu Oct 14, 2010 8:35 pm
ground clearance will not be your friend
You will probably find that you flatten your exhaust pipe on a semi regular basis between the sill and things like car park ramps
Postby iOnic » Thu Oct 14, 2010 8:54 pm
Ground clearance and I stopped being friends a long time ago.
d1 mule wrote:there are rules governing the distance the exhaust has to exti behind the rear most door, i think itssomewhere from 200-300mm from memory, which may be hard on the mr2 but apart from that DO IT!!!!!!!!!!!!
As far as I can tell from reading the VIRM there is no requirement for a specific distance from the rear most door. Aside from the usual noise level, I can't have them exiting on the left side of the vehicle for obvious reasons.
Postby duddley » Thu Oct 14, 2010 9:22 pm
I thought the distance was from the rear most opening window, would look nicer if you merged the two wastegate pipes into one the same size as your exhaust piping
i don't club seals..... only sandwiches
duddley
Postby Bling » Thu Oct 14, 2010 9:53 pm
iOnic wrote:Ground clearance and I stopped being friends a long time ago.
Shit that's low :lol:
Mine is 'low' but looks high which is gay, but I can barely get up my drive as it is....already hitting it at a 45..... how do you even drive it that low? :lol:
Postby touge_ae101 » Thu Oct 14, 2010 10:26 pm
obviously you avoid the square like a plague, there is no way you could get through some of those potholes like that ^^ :o
touge_ae101
Postby Elmendorf » Fri Oct 15, 2010 7:26 am
touge_ae101 wrote:obviously you avoid the square like a plague, there is no way you could get through some of those potholes like that ^^ :o
Its easy avoid driving around Palmy full stop. Luckily I had the fore thought to buy a house with a flat driveway, no angles onto the road, just an ever so slight bump into the garage.
I vote do it, especially since there is zero room out the back for your exhaust and it does look cool.
Elmendorf
Postby rollaholic » Fri Oct 15, 2010 7:44 am
do it
bonus points for boso pipes
Postby Leon » Fri Oct 15, 2010 7:46 am
http://www.nzta.govt.nz/resources/virm- ... xhaust.pdf
Page # 3
Reason For Rejection copy/paste from VIRM
5. The exhaust system is so constructed that emitted heat or fumes are likely to harm vehicle occupants, eg the exhaust gases are not directed away from the perimeter of the vehicle’s passenger compartment.
The exhaust photo you've got as an example looks to be directed away from the perimiter of the vehicles passenger compartment. Should be legal if it's not going to poison you, be too loud, or maim pedestrians.
Return to Polls
