Do You Use a Torque Wrench
Yes
39
71%
No
16
29%
Total votes : 55
Postby BZG Wagon » Sat Nov 12, 2011 6:15 pm
Talking with the GF's grandad (retired aircraft engineer); he reckons an overtight bolt is every bit as bad, if not worse, then an undertight bolt.
Which got me thinking - how do you know when a bolt is tight enough? Or do many of you use a torque wrench to get it right?
I'm referring to the bigger stuff here; sump plugs, large bolts, wheel nuts, etc.
BZG Wagon
Postby deaf_rattle » Sat Nov 12, 2011 6:45 pm
i always use a torque wrench when giving flat peakers the bash
Postby Mr Revhead » Sat Nov 12, 2011 6:46 pm
Yeah I use a torque wrench.
Not on sump bungs though! I do on wheel nuts.
Postby ch4ng » Sat Nov 12, 2011 6:52 pm
Yeah, on wheel nuts and engine internals
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Postby Dell'Orto » Sat Nov 12, 2011 7:03 pm
Definitely when tightening stuff into alloy!
Postby Mr Revhead » Sat Nov 12, 2011 7:05 pm
Dell'Orto wrote:Definitely when tightening stuff into alloy!
Relates to you latest "what did you do to your car today" contribution?
Postby Dell'Orto » Sat Nov 12, 2011 7:06 pm
No that was done with a torque wrench too :? but its hyper easy to strip threads in alloy if you use a breaker bar
Postby Adoom » Sat Nov 12, 2011 7:33 pm
Dell'Orto wrote: but its hyper easy to strip threads in alloy if you use a breaker bar
$&#$% AYE it is!! :evil:
Adoom
Postby Bling » Sat Nov 12, 2011 8:17 pm
Use one occasionally. Don't really do anything critical but the likes of wheel nuts it's handy for getting them all consistently tight. Other things I just use the right size tool as it's easier to know when it's tight. No 1/2" breaker bar on a 6mm bolt etc.
Postby 88.4ageGT » Sat Nov 12, 2011 8:32 pm
Haha we used one bolting the head back on dads mini but the torque wrench was wrong so when it was set at 50 it was act at 80 so we keeped going til the click and ended up snapping the stud in the block lol
AE92 4age GTi
Building 3sge ae92 race car
Malcolm wrote:I didn't know they had maths on waiheke
88.4ageGT
Postby 1I1 » Sat Nov 12, 2011 10:16 pm
Only ever use it on wheel nuts (don't normally do any other work that requires it). Usually get it about right but check to be sure.
TRD Clicky >>Here
1I1
Postby Mr Ree » Sat Nov 12, 2011 10:34 pm
Wheel nuts, and important internal bolts etc
wak thud gush!
Mr Ree
Postby matt dunn » Sat Nov 12, 2011 11:11 pm
I have only ever used one on headstuds and conrods/mains.
Everything else I do by hand.
Postby Grrrrrrr! » Sat Nov 12, 2011 11:18 pm
Everything inside the long block, and flywheel bolts + engine/gearbox mounts and sometimes wheel nuts.
Grrrrrrr!
Postby Lloyd » Sat Nov 12, 2011 11:54 pm
matt dunn wrote:I have only ever used one on headstuds and conrods/mains.
This. And cam bearing caps depending on the engine
People on here seriously use torque wrenches on wheel nuts??? I've only ever done that on rally cars
Postby Mr Revhead » Sun Nov 13, 2011 12:15 am
I do when working on other peoples cars :lol:
Postby Bling » Sun Nov 13, 2011 12:19 am
I do it as it's a quick way to know they are all at the same 'tightness'. No other reason.
Postby BZG Wagon » Sun Nov 13, 2011 1:07 am
Hmm... I've been looking for a while and based on the replies, I think I should invest in one.
They seem remarkably hard to come by (at least where I shop - mitre 10, BNT, ripco, supercheap etc) and the last few I've come across were around $200.
BZG Wagon
Postby Grrrrrrr! » Sun Nov 13, 2011 7:12 am
$200.... That's cheap. .
http://tradetools.co.nz/products/3755380
Its almost as tall as me. I want one to hang on the workshop wall.
A teng or other cheapish torque wrench can be had for a hundy in 3/8 which covers everything from cam caps to crank bolt on a 3s.
Grrrrrrr!
Postby iOnic » Sun Nov 13, 2011 9:41 am
Use them all the time at work on just about everything that could be a problem if it came off. Got a Torque wrench in every size from 1/4" to 1" inclusive. The 1" wrench is almost twice my height :lol: On my stuff I don't use it as much. Wheelnuts, brakes/suspension/steering, major engine bolts etc
Return to Polls
