1s/2c = R the bendy one
5k/g52 km36 looks like the M one with the notch out of the side, different clip and profile but same length and should interchange
colin dray once said to me there were 3 forks for w55/57/58 etc alloy supra box types, the straight, the notched and a 3rd which im guessing is the bendy
they are
not the same.. ie different in length between the pivot and the bearing and also between the pivot and the clutch slave contact point.
its about time someone made a comparison list! (for supra box unless stated)
notched = M, K (km36 G52), K A & T (only from 22spline T50) (shortest type) approx 113mm pivot to clutch slave
straight = T (3tgte), G, C (ce71), (middle type) approx 118mm pivot to slave
bent = R, S, C (cr30 G52), (longest type) approx 125mm pivot to slave.
<--- T and G (straight ie not notched or bent)
wanted to know...
JZ, RZ, L, Y,
also interesting to know... there are variations found on the same engine!
ie 1C bell from ce71 has different position of the clutch slave than say a 1C cr30 (same side but lower down and different fork)
would like to know other variations!
