engine break in
how did you break in your engine
SOFT break in
14
33%
HARD break in
29
67%
Total votes : 43
Postby edwagon » Tue Nov 06, 2012 12:15 pm
"Run it in...... or Run it out"
Just gotta load it it up - plenty throttle around peak torque - I wouldn't be redlining it but def plenty of load, and as above, don't be shy with the engine braking. I usually go up the motorway when its quiet in 3rd and accelerate from 60-100kmh and engine brake back down a dozen times or so
edwagon
Postby BZG Wagon » Tue Nov 06, 2012 1:12 pm
Sounds like it doesn't matter...
BZG Wagon
Postby KinLoud » Fri Nov 23, 2012 4:36 pm
edwagon wrote:"Run it in...... or Run it out"
This
Peak torque gives max cylinder pressure = max force pushing rings out to contact cylinder wall to wear the peaks off the crosshatch pattern
Engine braking helps to suck oil past the rings to lubricate, cool everything down a bit and help wash any metal away
Biggest threat is heat as extra friction in the first minutes of the run in could overheat things
So avoid max revs, 80% is fine for the first 20 mins of driving
Return to Polls
Fatal: Not able to open ./cache/data_global.php
