Tyre longevity
Tyre longevity
Postby RS13 » Sun Jan 07, 2018 12:45 am
Just over 2 years ago I replaced the Ecopias on our wagon due age cracking on the sidewalls. Just noticed today that all are starting to crack again in the same places, between the tread blocks on the outer edges of the tyres. We've done just over 20,000km in that time, always been within a psi or two of factory pressure.. what could cause this? Surely you'd expect to get more life out of them than that? Looked at the warranty, only seems to apply to tyres purchased from a Bridgestone outlet rather than the Tonys I bought them from.. so I don't fancy my chances. Should point out also that it gets driven daily by my wife so sitting around or harsh driving aren't factors. Manufacture date Jun 15.
Thoughts?
RS13
Re: Tyre longevity
Postby Leon » Tue Jan 09, 2018 7:03 pm
Two years is not good, assuming the cracking is serious.
I'd be going back to the purchaser, and asking them nicely to see if they will stand behind what they sold.
Re: Tyre longevity
Postby RS13 » Tue Jan 09, 2018 10:35 pm
Yeah. Spoke to Bridgestone, they reckoned it may either be high corner loads being a wagon or driving style. Their fix was to raise tyre pressures and drive slower around corners.. lol. He recommended replacing them with their new Ecopia model but I might try another brand, or try something a bit sportier. Still going to take them back but I'm picking they'll tell me their perfectly safe and there is nothing wrong with them.
RS13
Re: Tyre longevity
Postby wde_bdy » Wed Jan 10, 2018 8:20 am
If they don't want to play nice start mentioning Consumer Guarantees Act, should not happen under normal use or they aren't fit for purpose.
Callum
wde_bdy
Re: Tyre longevity
Postby RS13 » Fri Jan 12, 2018 12:16 am
Yeah for sure. Shouldn't have to slow down around corners just to stop the tyres cracking!
RS13
Re: Tyre longevity
Postby Al » Mon Jan 15, 2018 7:12 pm
Sounds like advice given to a mate that was having trouble with his home theatre system. Shop told him not to watch so many DVDs....
85 Corolla GT - 08 Blade Master G - 87 FX-GT
Al
Re: Tyre longevity
Postby RS13 » Tue Jan 16, 2018 4:46 am
Yeah, pretty stupid.. although talking to a former Bridgestone employee apparently the Ecopia tyres are terrible. Won't be getting them again! Running Yokohama Bluearths on my daily, aside from the high wear rate they're great tyres so might look into replacing the Ecopias with those. Really don't know if its' worth bothering with fuel saving tyres any more though!
RS13
Re: Tyre longevity
Postby Leon » Tue Jan 16, 2018 5:19 pm
I've got Ecopia's on the Prius. Well, two of them anyway.
They are terrible in the rain.
Ended up replacing two with normal budget tyres, just because the fuel economy ones my tyre supplier could get hold of were both terrible in rating, and also expensive.
Re: Tyre longevity
Postby RS13 » Wed Jan 17, 2018 2:06 am
I've never run budget/normal tyres on the wagon, only Ecopias.. economy isn't too bad around town, seems to hover around 10l/100km. I find they "tram track" pretty noticeably on smooth road surfaces, not the greatest in the wet but I've had worse. Did you notice fuel economy change much with the budget tyres?
RS13
Re: Tyre longevity
Postby Leon » Wed Jan 17, 2018 4:46 pm
Yup, fuel economy went downhill when I had the brand new budget tyres on the front, half worn Ecopia's on the rear.
After a few tanks, I did a front/back swap, to put the new budget rubber on the back, and the half worn Ecopia's on the front.
Fuel economy immediately improved.
But, important disclaimer, I haven't then swapped them back again, to see if the tyre rotation was the variable, rather than the weather being the variable. Because colder weather really hits Prius battery life, and I was pissing about with tyre swapping during winter. So the conclusion thus far is a non scientific, that all of the worse fuel economy figures achieved by the Prius were with budget front tyres and economy rear tyres. With the Prius having a barrage of different ways of showing you fuel economy, it registered thirstier several tanks in a row.
Re: Tyre longevity
Postby RAZA » Thu Jan 18, 2018 8:26 pm
I had a company car a few years ago that the company suddenly decreed that all their cars should be switched to fuel saving tyres so mine got switched from mid range michelins to ecopias.
It was immediately much more slippery in the wet and didn't seem to be noticably more economical. I put up with them as it was a free car, but I wouldn't hurry to put ecopias on my own car.
Currently driving:
BMW 135i M
RAZA
Re: Tyre longevity
Postby KinLoud » Thu Jan 18, 2018 9:27 pm
I have had a personal policy of putting high performance tyres on my cars for the last 15 years.
The last 2 sets of tyres have been Goodyear Eagle F1 Directional.
Lots of grip and enjoyment (and safety
Both sets got more than 60,000km so the cost per km of the tyres was the same or better than lower cost tyres I've had in the past.
I figure that the possible fuel i might save with eco tyres is outweighed by the long life of the performance tyres - also the improved safety of shorter wet stopping distance and grip.
Ive seen at a Toyspeed meet (Manfield 2006?) 2 identical cars with identical tyres stopping from 60kph
The cheap and cheerful tyres took 4 or 5 metres more to stop than the performance tyres - up to then I'd never thought there could be so much difference!
Re: Tyre longevity
Postby GDII » Thu Jan 25, 2018 8:50 am
Eco tyres are really scary in the wet. Any time you need to steer or stop to avoid a collision it's far harder to do so.
I've been running Toyo T1R on the MR2 for many years and now running Bridgestone RE003. I've never had any issues with grip in dry or wet.
The ECO cars I have owned however have run things like Firestone Supercats or Yokohama A drives. Supercats were pretty average but the car they were on was 710kg so not too much of an issue.
I had a set of BF Goodrich tyres (unknown model) on one of my cars, they were pretty good for cheap tyres.
I'd rather not drive around on rocks for tyres as I'm sure the fuel saving tyres are closer to a rock than rubber. Save money and crash or spend money and not crash. I know what I'd pick.
1990 SW20 MR2
Previous 1990 EE90 Corolla
GDII
Re: Tyre longevity
Postby GDII » Thu Feb 08, 2018 11:02 am
Just spoke to a Bridgestone employee. Told me Ecopia tyres are made from soft rubber to make them lighter so they wear out too fast and they chew out the edges. Interesting.
1990 SW20 MR2
GDII
Re: Tyre longevity
Postby RS13 » Sun Feb 11, 2018 2:09 pm
You'd think a softer rubber wouldn't crack that easily.
RS13
Re: Tyre longevity
Postby RS13 » Wed Apr 04, 2018 8:46 pm
Ended up with a set of RE003s as my local Bridgestone didn't have EP300s in stock so cut me a deal. Really happy, had forgotten how good performance tyres can be! Fuel usage appears to be unchanged over the Ecopias as well so far.
RS13
Re: Tyre longevity
Postby Boosted_162 » Tue Jun 12, 2018 5:45 pm
Going to hijack this thread as it is semi related tyre talk :lol:
Got myself a BP9 Outback (Subaru 8O) and need to replace the tyres. Looking at something mid range, mostly Hankooks at the moment as Hyper has them buy 3 get 1 free (plus I can pay them off) so open to suggestions for around $150-$180 a tyre. Was also looking at Toyo Proxies C1S if anyone has experience with them?
I'm running 215/55/17.
Oh yeah should probably add - I do about 80% open road driving, and do 25000-30000km a year on average.
Current: '05 Subaru Outback, '08 Mazda2
Re: Tyre longevity
Postby KinLoud » Mon Jun 18, 2018 8:06 pm
Go Goodyear Eagle F1 directional5
My last 2 sets have lasted 60,000km each - makes cheap tyre per km cost!
Great grip wet and dry
Re: Tyre longevity
Postby Boosted_162 » Wed Jun 20, 2018 7:55 pm
KinLoud wrote:Go Goodyear Eagle F1 directional5
Unfortunately they don't do my size, but I could go to either a 215/50 or 225/55.
Also unfortunately, they are almost $300 a tyre! Which is well out of my budget. Tis a shame as I've always found the older f1s to be an awesome tyre.
Re: Tyre longevity
Postby RS13 » Sun Jun 24, 2018 3:42 pm
Boosted_162 wrote:Going to hijack this thread as it is semi related tyre talk :lol:
Fill your boots mate! :lol:
Also the Eagle F1 comes in the Directional 5 (cheap) and Asymmetric 3 (not cheap!), the directionals are the ones Ken is talking about. I still rate the RE003s, shame Hyper don't do Bridgestone! I really can't fault them.
RS13
Fatal: Not able to open ./cache/data_global.php
