What engine for my KP60?
Postby Mr Revhead » Mon Apr 18, 2005 7:18 pm
hmm short on time....
how much can you do yaself? like rebuilding? modding to fit?
Postby fangsport » Mon Apr 18, 2005 7:19 pm
not sure where you will get one up your way, but they are out of a Swift and maybe the Baleno. i think it was hooked up to a T-50. If you want more info on the set up ,PM me, and i'll give you a contact to ring.
fangsport
Postby wde_bdy » Mon Apr 18, 2005 8:59 pm
If you go for the T series motor, PM me and I will send you some pics of one with engine, gearbox mounts etc. Not willing to post publicly as its not my car.
Callum
wde_bdy
Postby thaphatty » Mon Apr 18, 2005 10:02 pm
Mr Revhead wrote:a little out there, and maybe out of budget depending on what you can do your self..... but how about a 2ag? 2a with 4age head.....
something iv always wanted to try
drove an ae85 with one of those in once, loved the revs, probably the funnest thing i've ever driven, would deffinitely reccomend :)
thaphatty
Postby bad20v » Tue Apr 19, 2005 10:13 am
Mr Revhead wrote:hmm short on time....
Rebuilding and modifiing to fit is not a problem. I can do that myself. 'I have the technology'.
Thank-You.
bad20v
Postby RedMist » Tue Apr 19, 2005 11:07 am
fangsport. Yes that car is quick, I've saw it and approached the owner thinking it was a 4age... it certainly performed and sounded like one.
The G13 twin cam only came out on certain swifts. The single cam came in most swifts and the Blaeno and isnt a strong or high HP engine. The trouble with the G13 twin cam is its rare and wreckers tend to know that, so it attracts a premium.
Its an easy engine to develop and we had one in offroading pulling 140 hp on a dynojet.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Mr Revhead » Tue Apr 19, 2005 11:16 am
cool, well then the choice is yours!!
2tg
4k/5k modded
2ag/e
all have pros and cons!
Postby bad20v » Tue Apr 19, 2005 11:36 am
Hmmm.... I think I will go for a 4k as it will be easy to install and I can spend the rest of my time and money on modifing it for more power.
Cheers for the help. Would of liked to build some crazy as engine but when it comes down to it I need reliability and easy access to spare parts.
*runs off to look at TradeMe*
Thank-You.
bad20v
Postby Mr Revhead » Tue Apr 19, 2005 11:55 am
theres still the 5k option....
bolt in, rebuild with cam, solid lifters soem head work etc..... more torque than a 5k!
let us know how you get on!
Postby bad20v » Tue Apr 19, 2005 12:39 pm
I supose Toyota dont do them as an 'off the shelf' item no more? :lol:
Thank-You.
bad20v
Postby Mr Revhead » Tue Apr 19, 2005 12:42 pm
give me 2k and ill arrange one!!
but i can do some parts... solid lifters, gaskets, bearings etc etc
Postby bad20v » Wed Apr 27, 2005 11:24 am
Success!!!! :D
My brother and I have just purchased a 87 Corolla Wagon with a 4K and a 5 spd gearbox for $300. This will be the donor car for the starlet. The wagon has no wof or rego but all the running gear that we require is in mint condition. :D
Cheers for everyones advice. The starlet will be repowered this weekend!
If anyone is after any of the other parts on the wagon, I will be putting up a post soon in the For Sale Forum section, we will be selling the rest of the parts quite cheaply to get some money back on the initial purchase price.
Greg.
Thank-You.
bad20v
Postby wde_bdy » Wed Apr 27, 2005 1:44 pm
To quote me from Club K-
Corolla 5 speed to Starlet
There are 3 different K series 5 speed gearboxes, but we are only interested in 2 of them. Theses are the starlet k50 (hard to find) and the KE70 corolla K50 (easy to find). If you need a five speed for your starlet (or KE30 corolla) this is how you can put in the KE70 one.
To put in the corolla 5 speed you need a cold chisel and a drill. Line up the original starlet crossmember amd the new corolla one using the rubber mount. Mark the new holes and drill them. Then use the cold chisel and a hammer to cut away the bracing on the bottom of the starlet mount so that you can put the bolts through for the rubber corolla mount. This will make sense once you have it in front of you. If you can get a starlet 5 speed you don't have to cut the floor, but the corolla is easier to find. Be careful if you do cut the floor as the brake and fuel lines are right where you have to cut. Inside the car, simply cut the coin tray behind the gear lever out (this is for 1983 on models) and your gear lever will still fit in the centre console. You just need to cover the original hole. The original driveshaft will go straight in.
If you already have a 5 speed starlet box but smashed second gear doing smokies, you can just swap the tailshaft housings over from the starlet box to the corolla box. There are 6 bolts (VERY tight!!) to undo, remove the housing from the starlet box and sit it on the corolla box, and then you have to align the shifter rod with the shifter rails in the gearbox itself (so u can change gears). The will will then bolt straight back into the car.
Diff wise, the Corolla centre can be used in the Starlet casing IF you can get axles from a later 83-84 Starlet with the U code centre (you MAY be able to cut down the wagon axles). Driveshaft will also need shortening. If you can find the whole housing and driveshaft from the 83-84 Starlet it will be easier, and you can still slot in the low ratio wagon diff head.
Callum
wde_bdy
Postby ae82gt » Wed Apr 27, 2005 9:37 pm
bad20v wrote:Sorry, but even though i have easy access to a 12a rotary, its sitting in my garage, its kinda out of the question in the overall scheme of things.
Pistons only please.
:lol: il swap ya a 4age with loom and computor etc for ya 12a :wink:
fxgt ae82 20v
fxgt ae101
ae82gt
Postby bad20v » Mon May 09, 2005 12:00 pm
Sorry dude, the 12a's already got a home.
Thank-You.
bad20v
Postby bad20v » Mon May 09, 2005 12:01 pm
We put the 4k in, lowered the starlet 60mm and raced it yesterday, and it went mint!!! Heaps more power than the 2k!!!
Thank-You.
bad20v
