fuelling for a turbo setup
Postby rxtoy » Tue Apr 27, 2004 10:16 pm
i'm dropping a turbo engine into one of my projects (EX lancer, SOHC 4G63T for anyone interested) and i'm pretty sure i need to do something about the fuelling situation, i know i need at least a high pressure fuel pump (and yes, i'm considering your one EP71_4AGE) but do i NEED a surge tank and a lift pump or is this something for down the track when i'm starting to make a couple more horsepower???
and if i do NEED one then can someone draw me a basic picture of how it should be setup? like which pump goes where and return lines and all that other stuff that i'm not that sure about?
Matt
email diagram to str_ng_r@hotmail.com if you can't put it up on the site, that is of course if anybody can be bothered :D
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby slonlo » Tue Apr 27, 2004 10:54 pm
or the same but have the fuel pressure regulator going back to the tank
'89 LiteACE van
slonlo
Postby rxtoy » Tue Apr 27, 2004 11:11 pm
cheers mate, thats awesome!!!
just what i was hoping for.
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby matt dunn » Wed Apr 28, 2004 12:42 am
If you run from the regulator back to the tank the EFI pump may have mpre flow than the other pump and the surge tank will keep running out so it has to be done as per the diagram.
Postby rxtoy » Wed Apr 28, 2004 5:35 pm
out of interest how do fuel pressure regulators work? is it pretty much the same as a blow off valve, ie: the fuel pressure builds up in the manifold till it reaches a certain point where it relieves back to tank (or surge tank)
Matt
current rides:
76 stout
77 B1600 13B J port
rxtoy
Postby matt dunn » Wed Apr 28, 2004 8:52 pm
rxtoy wrote:out of interest how do fuel pressure regulators work? is it pretty much the same as a blow off valve, ie: the fuel pressure builds up in the manifold till it reaches a certain point where it relieves back to tank (or surge tank)
Matt
Kind of.
Fuel pressure builds up ib the fuel rail to about 40psi or whatever the spring pressure is,
and by applying vacuum or boost to it you can vary it up or down by a small amount.
Matt
Users browsing this forum: Majestic-12 [Bot] and 67 guests
