Mr Revhead wrote:starter contacts? if its done it once, and you fix nothing itll do it again!
if it was contacts he would here the the 'clink' of the plunger in the solenoid engaging
tianporn wrote:Do Toyota's have a fuel pump relay. It may need to get resoldered. Common as problem on Hondas[
Audi wrote:...it won't even try to turn over. The battery seems to be fine and I tried jumping it to no avail. It doesn't turn at all. I turn the key and nothing.
Users browsing this forum: No registered users and 84 guests
