How to decode ae111 codes (bz-r bz-g etc)
Postby Mr Revhead » Thu Mar 17, 2005 6:46 pm
a= a series engine
e= corolla
1
1
1
a= levin b=trueno c=carib
c=coupe e=four door so when its ae=corolla be=sprinter ac=levin bc=trueno
m=5spd p=auto f=6spd manual
g= low spec (xz,ztouring) v=sports type bz-r, bz-v (before facelift) gt 4door
z= luxury spec bz-g bzt
f= 4age k=4afe
most of the above also applies to the ae101 sereis, and others
iv missed a couple out for things like the spacio cause i didnt really think many cared about them!
if you have a car with numbers that are different let me know and ill decode it for you 8)
to clear a few misconceptions up.....
gearboxes
BZ-R are all 6 speed manual.
BZ-G can be either maual or auto all 6speed after 4th 97
BZ-V can be either 5spd manual or auto, untill facelift in 4th 97 then they are all autos, but sports type but with out LSD. which i find odd. i have yet to see one of these.
diffs
BZ-R are LSD from factory
BZ-G are open if non s/s. prefacelift s/s are LSD. all facelift have s/s but are open
BZ-V are lsd if manul, autos are open
thatll do for now, any questions?
Re: How to decode ae111 codes (bz-r bz-g etc)
Postby CozmoNz » Fri Mar 18, 2005 2:45 pm
Mr Revhead wrote:BZ-V can be either, untill facelift in 4th 97 then they are all autos, but sports type but with out LSD. which i find odd. i have yet to see one of these.
Your contradicting yourself....
*Bz-v were Sports type without LSD
then follow to say if they are manual they are LSD.
Last time i pmed u, i sent my chassie code and such, you replayed with *it is an LSD gearbox* etc.
So... are they optional? All lsd, or all open?
Rayne For President!
CozmoNz
Postby JT » Fri Mar 18, 2005 3:01 pm
Read it again. If it's BZ-V made after 4th '97 then it is an auto with an open diff. It it was made before then and is a manual, it has an lsd.
JT
Postby Mr Revhead » Fri Mar 18, 2005 3:12 pm
have edited to make it clearer :wink:
the top parts is about gearboxes, lower diffs
Postby JT » Fri Mar 18, 2005 3:23 pm
Hmmm, so all BZ-G's supposedly have open diffs. That does go against the grain of previous ideas.
What about 6 speed BZ-G's and BZ-V's, were they a factory option then? Which means they bothered to put a 6 speed in the BZ-G but didn't put an lsd in it. Weird.
JT
Postby Mr Revhead » Fri Mar 18, 2005 3:26 pm
no lsd at all shown on the EPC for the bz-g facelift
thats part of what makes the bz-r different 8)
Postby CozmoNz » Fri Mar 18, 2005 3:26 pm
thanks, sorry, wee bit confusing there.
So bz-v, Pre 97 Manual Had LSD, after Had open.
Whamo.
Since the 6sp came from the Bz-r, id imagine all 6sp are lsd.
CozmoNz
Postby Mr Revhead » Fri Mar 18, 2005 3:28 pm
read it again.... carefully.....
after 4th 97 ALL bz-v are auto only.
there is mopre than one version of the 6speed.... bz-r ones are lad. bz-g are not
Postby CozmoNz » Fri Mar 18, 2005 3:38 pm
Mr Revhead wrote:read it again.... carefully.....
i havnt actually seen a 97+ bz-v anyway. But yeh, my bad.
did not know that about the gearboxes, thought they were all the same...
what about the XZ etc models, they have different chassie codes.... your explaination dosnt cover why. AE100, AE110 (AE111 Shape...) but whats different?
CozmoNz
Postby Mr Revhead » Fri Mar 18, 2005 3:44 pm
ae100 and ae110 are different models.... ae100 is the 5a engined equiv of the ae101 and the ae110 equiv of the ae111. ae112 is ae112.
i left those out casue to explain all the extras there would take far to long.
and no one really cares!
Postby BZG » Fri Mar 18, 2005 8:06 pm
They are BZ-Rs which are automatic...... :o
BZG
Postby Flyboy » Fri Mar 18, 2005 8:40 pm
Mr Revhead wrote:diffs
BZ-G are open
Then why does my 6-speed BZ-G have LSD?
Flyboy
Postby Mr Revhead » Fri Mar 18, 2005 8:58 pm
either it doesnt or its been fitted after it left the factory
go look at ya trans code and tell me what it says. the FULL code
Postby TRDWGN » Sun Mar 20, 2005 8:55 am
BZ-G are open
:lol: Maybe it is a BZ-R that has been modded to look like a BZ-G....
No doubt your car was optioned up with an LSD, my carib is in the same situation, afaik they never came factory fitted with an LSD but it definitely has one!
TRDWGN
Postby Flyboy » Sun Mar 20, 2005 9:59 am
Ill look at the chassis code 2nite..... It seems to have most of the BZ-R options.... :wink:
Flyboy
Postby Mr Revhead » Sun Mar 20, 2005 12:04 pm
the fact is there is very little mechanical difference between the bz-r and the bz-g.
TRDWGN send me ya model, frame and trans codes, and ill do some digging for ya
Postby alastabesta » Sun Mar 20, 2005 2:39 pm
sure I've heard 4A transmissions in a bzr before... :roll:
2001 Caldina GT-T
alastabesta
Postby Flyboy » Sun Mar 20, 2005 9:55 pm
My Chassis code is E-AE111-BCFZF
MY Trans code is C160-12A
Is that everything u need Warwick?
Flyboy
Postby Alex B » Sun Mar 20, 2005 10:11 pm
if you read the top post flyboy you will see that the Z second from the end is showing you are the prowd owner of a BZ-G
BCFZF
b=trueno
c=coupe
f=6spd manual
f= 4age
LSD must be aftermarket
Postby TRDWGN » Sun Mar 20, 2005 10:39 pm
Flyboy wrote:My Chassis code is E-AE111-BCFZF
From an earlier post on a similar topic Warwick mentioned the last letter of the transaxle code relates to the diff
a= open
c= LSD (Factory)
Don't forget though that there are plenty of people who fit an aftermarket LSD in so nothing is guaranteed until you pull the box apart and check it out for yourself!!!
TRDWGN
