Altezza Potential?
Altezza Potential?
Postby Luke - BZG » Tue Mar 22, 2005 6:19 pm
Thinking about what to get for my next car. An altezza would be nice, but im wondering what could be done in the engine department. If the 3 litre 6 cylinder 2JZ-GE from the wagon has more moding potential than the 2 litre 4 cylinder 3S-GE can they be swapped around? any other info would be good.
Cheers :wink:
Luke - BZG
well
Postby TRDmod » Tue Mar 22, 2005 7:21 pm
the 2 litre 4cyl beams engine has huge poteltial, i mean N A alone it has good kw ratings, you can always get a hks or reddy turbo kit made for altezzas....not expensive, low psi and get yourself 210 kw easy
in fact specr has the UNFAIR altezza, saw it today, it has alot of power, rear wheel drive too...and they look good.....so maybe you should see hima nd ask him what he has done and do the same
or if u wanna stick to na, im sure there are plenty to do, trd catalogue has lots of them from computer chips to exhaust...
Domino's Pizza.....
TRDmod
Postby Al » Tue Mar 22, 2005 9:42 pm
MR2 turbo pistons. Pump gas. Piddly td04 @ 10psi = 160rwkw.
http://toyspeed.blakjak.net/profiles/profile.php?id=444
Al
Postby TRDWGN » Tue Mar 22, 2005 10:18 pm
V8 or Supra TT conversion will do quite nicely thank you!!!
Rod Millan did a one-off for SEMA show last year or the year before, chucked a V8 and 6spd box in it, labelled it the IS430, google it and see what you find, saw it on Sky drifting quite nicely around a track with a oh so glorious growl!!
TRDWGN
Postby beeker » Tue Mar 22, 2005 10:29 pm
There is a nice yellow v8 conversion done as a race car. Mind you it cost them close to six figures. The job is supreme though.
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby Truenotch » Tue Mar 22, 2005 10:31 pm
Yeah that car did the targa. Nice job indeed
Truenotch
Postby Mr Revhead » Tue Mar 22, 2005 10:33 pm
all depends on ya budget!!
throw me enough cash and im sure i could arrange a 2uz-ftte :twisted:
but yes the TRD catalouge does ahve a few tasty bits for them!
dunno bout the chip though.....
Postby Luke - BZG » Tue Mar 22, 2005 10:34 pm
http://english.auto.vl.ru/catalog/583/
It's saying on here that it should almost put that much power out as stock? But maybe thats the same case as the Levin supposedly putting out 165hp stock.
Luke - BZG
Postby beeker » Tue Mar 22, 2005 10:49 pm
4age_aw11_ae86 wrote:Yeah that car did the targa. Nice job indeed
It was built for the Bathurst Endurance race. Targa was a run in.
06 RS4 Avant
beeker
Postby JT » Tue Mar 22, 2005 11:02 pm
The factory rated figure of 154kw is at the fly and probably is a usual toyota figure. The turbo tezza in that link is 160kw at the wheels and has a whole lot more torque!
JT
Postby Mr Revhead » Tue Mar 22, 2005 11:05 pm
torques where its at!!
thas why i talk so much..... to compensate for the 20v...... :lol:
Re: well
Postby anthonym » Wed Mar 23, 2005 8:10 am
TRDmod wrote:the 2 litre 4cyl beams engine has huge poteltial, i mean N A alone it has good kw ratings, you can always get a hks or reddy turbo kit made for altezzas....not expensive, low psi and get yourself 210 kw easy
Sorry but that's utter BS, these kits may be relatively inexpensive (depending on your definition) but they are bodge. It costs a lot of money to effectively and reliably turbocharge the Altezza 3SGE. Turbotezza has spent a fortune making his reliable after it blew up using one of these kits, and he's still making less power than the Toyota NZ Altezza touring cars were making NA.
IMO you'd need to spend $15-20k to turbocharge the Altezza 3SGE and achieve a reliable power output worthy the investment. For that sort of coin you could do a 2JZGTE transplant. Or if you just want good power and torque, the 2JZGE Altezzas/IS300s are outstanding cars bone stock, even with the auto box.
anthonym
Postby thaphatty » Wed Mar 23, 2005 8:51 am
lol yeah the first 10 minutes of it. he got it sorted later on though.
was crack up watching him run from the cops on his way back from the motorshow though :lol:
thaphatty
Postby turbo tezza » Wed Mar 23, 2005 10:45 pm
nemesis wrote:Sorry but that's utter BS, these kits may be relatively inexpensive (depending on your definition) but they are bodge. It costs a lot of money to effectively and reliably turbocharge the Altezza 3SGE. Turbotezza has spent a fortune making his reliable after it blew up using one of these kits, and he's still making less power than the Toyota NZ Altezza touring cars were making NA
This is coz my car is in very mild tune. If i wanted to run more boost i could, with more advance, it would be over 200 rwkw, thing is i don't need any more power. Its fine just the way it is.
And yes the engine has alot of potential.
You would be struggling to do a 2JZGTE coversion for near $10K. Engine to start with are about $4k.
UZ would be the way to go..... :)
turbo tezza
Postby anthonym » Thu Mar 24, 2005 8:10 am
turbo tezza wrote:This is coz my car is in very mild tune. If i wanted to run more boost i could, with more advance, it would be over 200 rwkw,
Maybe, but until you do it's speculation, and I'd suggest not without spending even more money on a bigger turbo at least.
I accept that, my point was the amount of money expended relative to the reliable power improvement gained.
Yes but that's true of any engine if you spend enough money. IMO the cost benefit of turbocharging the Altezza engine is poor unless you are aiming for a significant HP gain from the outset. Even then an engine transplant is probably going to be cheaper and at least as effective.
But you would be strugging even harder to get equivalent reliable power from a turbo Altezza 3SGE. How much have you spent? :)
Possibly, but it would involve a lot more custom fabrication work than a 2JZGTE and has less power potential without significant modification.
anthonym
Postby beeker » Thu Mar 24, 2005 8:55 am
With trying to piss anybody off, it is impossible to beat OEM engineering for value for money and reliability. It might look like it at the beginning, but over time you just cant do it. These OEM's spend hundreds of millions on R&D, and you just cant replicate that in your back shed or small tuning house. I would personally either do a mild tune or if reengine with a proven engineered end to end solution.
06 RS4 Avant
beeker
Postby Inane » Thu Mar 24, 2005 10:04 am
Mr Revhead wrote:all depends on ya budget!!
how about a 1FZ-FTTE?? :twisted:
Inane
Postby TRDWGN » Thu Mar 24, 2005 7:45 pm
beeker wrote:With trying to piss anybody off, it is impossible to beat OEM engineering for value for money and reliability. It might look like it at the beginning, but over time you just cant do it. These OEM's spend hundreds of millions on R&D, and you just cant replicate that in your back shed or small tuning house. I would personally either do a mild tune or if reengine with a proven engineered end to end solution.
Word!!!
Why do people assume that it is possible to out engineer a team of highly educated,skilled and experienced engineers?....
HP costs a lot of money, reliability costs even more
TRDWGN
Postby Adamal » Thu Mar 24, 2005 8:14 pm
The thing is that the engines are built with a certain purpose in mind:
Daily driving.
For this, they shouldn't be too loud. Not everyone wants a loud induction sound as well as a huge blaring exhaust note. There are some that do, but they represent a small minority compared to the rest of the consumer market.
All round power is another one. When you start tuning a car, you tend to sacrifice power or response in part of the rev range for a gain in another.
For example, big cams in an N/A will give you more power up high, but rob you of it down low. If you're driving a car around town, you don't want that.
There are other reasons too, but thats why each of the companies has their own motorsports group. TRD, Nismo, Ralliart etc etc. So that when people want to use these cars in motorsport, they can get the parts they need to make it a very competative car that won't need to meet a daily drivers requirements.
Postby ROBODISCO_20v » Thu Mar 24, 2005 10:57 pm
If you get a chance check out the best motoring series of dvd's. One has the trd altezza on it. It has things like quad throttle bodies on it that they claim gave it an extra 20hp instantly. All up the thing is making 280ps out of a 2L NA. Revs out to 9K too! Just like a VTEC, only better :!:
ROBODISCO_20v
