The problem with 5.1, is that it doesn't absorb moisture.
TygerTung wrote:The problem with 5.1, is that it doesn't absorb moisture.
vvega wrote:but in saying that i belive the silicone based product is still better
Mmm, Boost wrote:vvega wrote:but in saying that i belive the silicone based product is still better
Why is that? I was lead to believe it makes the pedal kinda spongy due to the compressability of the fluid?
You are confused with DOT 5, which is silicone based. DOT 5.1 is generally for synthetic (not silicone) fluids and is the highest rating available.
