I have heard a bit of discussion here and there, about SW20s generating
lift at the front, at high speeds. (noticable at 80+)
Some suggested that a deeper front lip helps alleviate this.
However, surely the difference is minimal, compared to rerouting the
path that the radiator air takes. If you look at the radiator
arrangement, it is... weird. The radiator itself is slightly leaned back
at the top. The air flows in at the front or the car, gets pushed
through the radiator, and then pushed out straight under the car. If you
look at the cross sectional area of the radiator, compared to the
larger lip, it is a huge difference. Plus, Wouldnt the lip just be
scooping more air up into the radiator anyway? Which goes straight back
under the car.
I have seen a few MR2s that cut a hole into the front area where the
spare wheel is. Then, they vent the air up through the bonnet, over the
top of the car.
This is actually a very clever idea! the air moving upwards creates
downforce on the front, as well as reducing the pressure of the air
under the car.
It is also a good idea, because it is REDUCING lift, rather than
creating more downforce, to counteract the lift. As you may be aware,
both lift and downforce create drag. If you add a wing or whatever to
the front, you are increasing the drag created to produce downforce, but
not addressing the actual problem.
At first when I saw vents on the front bonnet of an SW20, I thought it
was just 'wank factor'. How wrong I was!
This is how almost all other mid engined cars vent the radiator air. (see
a lotus elise, ferrari f40, etc.)
Its just something I have been pondering for a while.
I have run a cross section of the SW20 through my wind tunnel simulator.
After 3 days of number crunching and calculations, this is what my super computer spat out.
Now there are some interesting observations to be made here. You can see what I mean about the standard radiator positioning. This air gets pushed back under the car. This means that the air under the car is at a higher pressure than it would be otherwise.
The second picture down shows how I think the radiator mod would work. One thing that I noticed however, is the shape that is made between the top of the radiator venting, and the front part of the bonnet. It is a classic aeroplane wing shape. Would this generate lift anyway? Perhaps a downwards facing bulge would help prevent this. (making it more of a teardrop shape.)
One thing that is concerning about this idea, is the increased pressure on the front wind screen/roof. Would this create more drag, than if the air simply travelled under the car? Especially since there will be more air going off the 'drop off' where the rear window is.
Perhaps diverting the air out the top, and then around the sides of the car would be the ideal solution.
One thing that I havent drawn in, but I think is relevant is the stock muffler. Notice how it is oval shaped, and spans across the whole length of the back of the car? Perhaps this was designed to work as a crude venturi, or working on the same principal as a spoiler, but for the air flowing underneath the car. If so, very clever.
Also, I havent included the side vents. Not for any reason, I just forgot.
The bottom pic, is what I think will happen with a larger front lip. I mean the air has to go somewhere, right? I am sure it helps though, perhaps it diverts the air around the car, rather than under/over.
So, in conclusion, there is no real point to this post.
I just had to get that out, my friends start looking at me like a nutter when I harp on about air flow, pressure, venturis, etc.
