4age common low idle problem fix?
Postby gmacrae » Fri Jun 03, 2005 1:28 am
Hi ppl, my fxgt has a very low idle when its hot, common problem with 4age's i know. Has anyone ever actually worked out a fix? idle speed isnt actually adjustable is it?
just sick of pulling up to light and having the car stall on me, any info would be great - Cheers
Gene
gmacrae
Postby THA SHZ » Fri Jun 03, 2005 9:30 am
check ur thermostat and fan is workin , this was the probs in mine :)
THA SHZ
Postby gmacrae » Fri Jun 03, 2005 9:42 am
ah yep, had the thermostat out on the weekend, ran the water temp sensor dry till the thermostat opened back up, i bet the ecu is still freaking out about that, ill clear it and see what happens - Cheers:)
gmacrae
Postby ChaosAD » Fri Jun 03, 2005 7:26 pm
yes there is an idle adjustment screw. its down a hole on the top of the throttle body. may or may not have a cap covering it
ChaosAD
Postby dxtawagon » Fri Jun 03, 2005 7:32 pm
yes i have this problem too. its freakin anoying still dont know what it is or how to fix it??
hope someone posts a solution to this problem
dxtawagon
Postby Mr Revhead » Fri Jun 03, 2005 7:49 pm
sticking idle valve?
iv heard of them idling high, but not low.....
Postby matt dunn » Fri Jun 03, 2005 8:24 pm
ChaosAD wrote:yes there is an idle adjustment screw. its down a hole on the top of the throttle body. may or may not have a cap covering it
To correctly adjust idle speed you must
first set the TPS correctly.
then set the
Ign timing correctly,
then you can adjust the
idle speed.
If they are not correct and not done in that order it will not be correct.
Matt
Postby kingcorolla » Sat Jun 04, 2005 4:06 pm
yep that bastard cold idle valve is a common one.
When the car is up to temp, (and idling low) try blocking the air entry port on the filter side of the throttle plate. If your idle stays the same then that idicates there is little air exiting the valve. If the engine dies when you block it then the could be elswhere. Clean it out and give it a blow with a duster gun if you can be f%$#d
doing TPS and setting base idle to start with is definately a good idea
1983 Carina AA63 4age
kingcorolla
Postby ae92levin » Sat Jun 04, 2005 5:42 pm
yeah my 4age used to do that, just turned up the idle.
Now: 94' Mark II grande; 92' gt starlet ha
then: x3 4agze ae92; 4agte ae92; e30 bmw
ae92levin
Postby yobbosayo » Tue Jun 07, 2005 10:45 pm
from what I've read on here this is a common fault and it is caused by the auxiliary air valve.
Mine does exactly the same thing, stalls at idle when hot, so I finally bought the part that I hope will fix it. I was going to put it in on the weekend but i realised that I needed the gaskets so I ordered those today. I'll report back if it fixes the problem.
Just check the haynes manual, there's a section on testing and replacing the auxiliary air valve. It sits just underneath the throttle body. Of course I didn't bother with testing it, cos I prefer to throw my money away in the hope of a fix :roll: so it will be interesting.
I bought the part off revhead, $185 delivered, so the price is what puts most people off fixing them. Oh, and you will need the gasket and o-ring for the valve, and the gasket for the throttle body too, which altogether cost about $15.
yobbosayo
Postby suberimakuri » Wed Jun 08, 2005 1:12 pm
i always pull off the water stuff under the throttle and block it up.
warm idle about 200rpm higher then cold idle.
suberimakuri
Postby CAMB01 » Wed Jun 08, 2005 8:48 pm
4AGEs need stepper motors, like mitsi's do.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby suberimakuri » Wed Jun 08, 2005 8:52 pm
nope.
suberimakuri
Postby ndeany » Thu Jun 09, 2005 12:31 pm
my ae101 4agze is doing the same thing at the moment... Replaced the air filter, needed a new one anyways, but no difference... Well the only difference is that she aint stalling anymore, but still idles at about 500rpm when hot.. If you play with the idle won't it therefore idle too high when the choke is engauged, but then obviously be sweet when not engauged??? Surely there's an actual way to fix the problem, rather than trying to compensate by uping the idle... I'm getting mine looked at today by a local mechanic that used to work for toyota... Let you know how it goes...
ndeany
Postby NZ_AE86 » Thu Jun 09, 2005 2:16 pm
then set the
idle speed.
Matt
As Matt said. It is a very simple system, the only other thing is to make sure that the car is coming up to correct temp and STAYING there. Then do as Matt says.
NZ_AE86
Postby ndeany » Fri Jun 10, 2005 3:26 pm
ive just had my low idling problem fixed. all that the bill says is: "brought car up to temperature. Checked idle. Slightly low. Checked and cleaned all electronic connections and vacuum lines. Adjusted idle screw so that will idle at approximately 750rpm. Road tested and rechecked. All ok."
ndeany
Postby ChaosAD » Fri Jun 10, 2005 7:14 pm
What the cold idle valve does is let extra air into the manifold when the car is cold.
Water from the cooling system is fed into it and when the coolant heats up it melts a wax pellet in the valve causing it so close the cold idle valve and drop the idle.
The pellet is easily damaged by overheating and possibly age. When it is damaged it will let air into the manifold wether the engine is cold or warm.
This causes a the car to continually idle high even after it has warmed up. This usually cannot be cured by adjusting the idle screw as the cold idle valve simply lets too much air in.
If the car ildes too low then just give it a tune up and adjust it as detailed above.
ChaosAD
Postby yobbosayo » Fri Jun 10, 2005 10:46 pm
yep, well I fixed it. It cost me $200 and then I find out I could have just adjusted the idle screw which is sitting on top of the throttle body. 8O
well maybe. Mines a bluetop and I replaced the part then adjusted the idle like the haynes manual said, and now it's pretty much perfect. cold idle at about 1500, and hot about 800. So who knows. It wouldn't surprise me if I spent $200 for nothing. One day I'll learn how to stop wasting money on cars
yobbosayo
Postby rwd_mayhem » Thu Nov 16, 2006 7:35 pm
Karl_Skewes wrote:i always pull off the water stuff under the throttle and block it up.
so that doesnt effect it too much? wont die when cold? iv thought about doing this as mine are not connected at all and it revs from 2200-3000 eractically.
current: 1975 Valiant Regel
previous: 1980 mazda 626, 4AGE AE70 sedan, AE70 sedan, mk2 escort, KP60 starlet, TE71 liftback X2
rwd_mayhem
Postby l1ttle_d3vil » Thu Nov 16, 2006 9:22 pm
the erratic idle will probably be as a result of too much air going into the engine, so your idle is probably set too high, or the aux bypass valve is stuck open or something along those lines.
i've removed all the waterlines and bypass valve on my 4age too, alot tidier without all those waterlines. it starts fine, even on cold mornings and idles at about 800rpm when dead cold, and about 1200rpm when warm. I can lift the idle a bit, but then its too high once it warms up.
it isnt too bad when cold, but if I hit the gas then let the revs drop to an idle it'll shudder slightly as if its almost going to stall, but never does. thats only for about the first 30 - 60 seconds anyway.
