4wd corola wagon engine converstion
Postby DNTASK » Wed Jul 06, 2005 6:49 pm
my mate has a 96 corola wagon, 4wd with the 4AFE he is wanting to know whether its possible to convert it to a 4AGZE while still maintaining the 4wd. wondering if anyone knows if its possible and what wd need to be done. will he be able to use the same gearbox and if the driveshaft needs to be shortened or anything like that. are the engine mounts the same, obviously it would need to be certified right?
any help would be much appreciated
doin it sideways
DNTASK
Postby Ae92typeX » Wed Jul 06, 2005 7:25 pm
possibly the box would be the weak point when put up to the power of the ze compared to the fe. Not 100% sure, but should bolt up, may have to play around with engine mounts. Obvously 4agze loom etc. Have you tried a search? I recall someone talking about it some time ago
Ae92typeX
Postby NZcelica » Thu Jul 07, 2005 12:32 am
she'll bolt up easy as pie, and I think a 4AGZE should work fine.
Considering a T3 turbo 4AGTE can be powered through the standard gearbox!
http://www.turbocorolla.com/cars/larsc.htm
ST165 Celica GT-4 <SOLD>
97 GT-T 18psi <GONE>
96 Carib BZ 5 speed
Looking to import a car? PM me
Lots of performance Toyotas forsale. PM me for details
NZcelica
Postby Alex B » Thu Jul 07, 2005 12:35 am
I dont think the box will hold up to it, but yes the engine will boly up easy.
Postby quinny » Thu Jul 07, 2005 1:42 am
not confident on the box myself either, and find another one in a hurry!
currently beating - AE101 Sedan, blacktop/6spd, tein coilovers, braided lines, cup holder, and every other bloody thing possible.
quinny
Postby Alex B » Thu Jul 07, 2005 1:43 am
such an ass to change the box on em tho :roll:
Postby NZcelica » Thu Jul 07, 2005 10:29 am
naaaa i did mine in an afternoon, just drop the engine out the bottom with the box is the easiest way
96 Carib BZ 5 speed
NZcelica
Postby Alex B » Thu Jul 07, 2005 7:45 pm
yours isnt an AE chassie tho, trust me we tried everything, You have to drop out the box/engine and subframe.
Postby CozmoNz » Thu Jul 07, 2005 9:26 pm
pyro_sniper2002 wrote:yours isnt an AE chassie tho, trust me we tried everything, You have to drop out the box/engine and subframe.
you didnt tell me you had a gt-four!
you putting a 4efte in now andrew? *evil grin* DO IT DO IT.
4x4 races through the mud!, samuri vs corolla 2
Rayne For President!
CozmoNz
Postby Hazardous » Fri Jul 08, 2005 7:16 pm
hey mate have u put it in or deceided if it will fit or not and does it all bolt up sweet including gear box
Hazardous
Postby XSVWGN » Fri Jul 08, 2005 7:17 pm
i have an ae100 wagon with the ae92 4agze. I contemplated changing it to four wheel drive but decided against it. The ZE will bolt straight up but as the others have said you will have troubles with the gearbox. LOMOFO on here also has a ae series wagon with a ZE so you could always ask him about this modification
Matt
2008 Kia rio - work car
XSVWGN
Postby Alex B » Fri Jul 08, 2005 7:32 pm
at most id put a 20v in, even that probly wouldnt last long
Postby XSVWGN » Mon Jul 11, 2005 2:16 pm
viewtopic.php?t=32117
have a read of this gearbox wise and see what you think.May make the conversion alittle easier
XSVWGN
Postby Alex B » Mon Jul 11, 2005 4:40 pm
IS that saying gt4 parts will fit in the box :?
If so i now have no reason to sell my car ever :lol:
Postby Malcolm » Mon Jul 11, 2005 4:58 pm
only if your gearbox is already an e5* or other E series box. If it's a c5* etc then nothing will fit.
Postby Alex B » Mon Jul 11, 2005 5:07 pm
E55F5-824?
So it will work then. :arrow:
Postby DNTASK » Mon Jul 11, 2005 5:14 pm
cheers for all the input guys, its just a plan that my mate was having for his car at the mo. he wants the 4AGZE for a bit of extra power for getting up the mountain in ski season, its a big slugish at the mo so yeah wanting to keep the 4wd. so do u know it there is a way to modify the gt-4 box to blot up onto the back of the 4agze? just a thought. but then wd need to modify a drive shaft as well ay. then it would probly be best to go with a gt-4 diff as well ay, bcoz the standard one may not hold up to the power increase...
i wasnt too sure about whether the 4agze mounts wd be the same as the 4afe, but if u rekon they are, sweet.
weve done a few conversions on other cars (mostly nissan) so will be able to do the transplants no problems, just wondering whether it would all work out sweet as.
doin it sideways
DNTASK
Postby Malcolm » Mon Jul 11, 2005 8:11 pm
I don't know much about E55F5's, but from what I've seen in comparisons between E51 (mr2 4agze box), E153 (mr2 3sgte box) and E150F(gt4 3sgte box), you should, theoretically, be able to put a 4a bellhousing from your current gearbox or an E51 onto a gt4 E150F (or other gt4 box), which will should work fine on the 4agze.
However, there shouldn't be a huge difference in strength between what you have and a gt4 box, as they're both from the same family, and hould have very similar internals. There may be differences in the transfer box, or the diffs inside the boxes. The driveshafts should fit too, as they do between E51, E153 and E150F.
The rear diff might be able to swap, but if it can then there is also a chance that it's not much of an upgrade, unless you don't currently have an LSD, most gt4's have TorSen diffs.
Postby Malcolm » Mon Jul 11, 2005 8:15 pm
can I make a suggestion that if you're going to put a 4agze in, you'd might aswell go a step further and put a 3sgte + gt4 box in.
If you are keen on this idea then send me a PM, the gt4 box should go in with the same mounts (just have to change the front bellhousing mount), and make a new cambelt end mount. Since you're out west I should be able to lend some help from my experience with gt4's and engine conversions :)
Postby DNTASK » Tue Jul 12, 2005 4:42 pm
ill pass all this info onto my mate and see wat he has to say, im pretty sure that the wagon has an LSD, its got the switch which locks the diff for getting out of slippery situations...
doin it sideways
DNTASK
