THE FORUM RULES
THE FORUM RULES
Postby BlakJak » Fri Jul 29, 2005 8:24 pm
Board Rules
The forum rules basically come down to a few key concepts:
- Be considerate of other forum users.
I've amended these rules so its no longer just '8 simple forum rules' - however nothing here is particularly unusual. Some further more specific rules are listed below:
- If you post blatantly incorrect or misleading technical information it will be removed.
- If you repeatedly attack another user in a thread your entire post will be edited out. If you continue to do this your account will be suspended.
- If the content should not be viewed in a ‘business/office’ environment then it’s not acceptable material for Toyspeed considering, possible age of our members and of course maintaining a respectable reputation in the public eye.
- No more than 6 lines of text or a graphic no larger than 100x500 in your board signature. Further, these should not be of excessive size (in bytes) - thus be considerate when using large animations, etc.
- Images posted into threads directly via [img] tags should not be bigger than 800x600 pixels in most instances. If you need to refer to a bigger image, just post a URL instead of using img tags.
- No businesses are to post For Sale information on the forum unless they sponsor the club. The exception to this is forum users who contribute proactively to the wealth of content on the board.
- Off-topic is for non car related discussions but spam or dribble is not permitted. Posts that are a waste of bandwidth will be deleted without reservation.
- Repeated posts where a user hasn't searched will be locked.
- 'Aggravating' posts in other peoples For Sale threads will not be tolerated, however if someone is being obviously misleading then a post to point this out is acceptable.
- Moderators reserve the right to moderate your posts in any way they see fit to conform to these rules. Generally if a post is unacceptable its content will be edited out so the user knows what happened.
- We kindly request that the position of the Moderators be respected. We have the occaisionally awkward task of trying to find the neutral ground between opposing parties - so a little understanding goes a long way.
Thanks for your time!
- BlakJak, for the Mod Squad.
BlakJak
Postby BlakJak » Sat Sep 24, 2005 7:31 pm
As an addendum to the above please also note the following:
*Members are advised to check out the FAQ Section before posting questions.
* As at this week the Toyspeed Rules and Disclaimer have been updated, please refer to http://www.toyspeed.org.nz/disclaimer.html .
* If you need help or info on a Toyspeed Administrative issue theres a thread Sticky'd at the top of the FAQ section - refer to viewtopic.php?t=34474 .
BJ.
BlakJak
Postby BlakJak » Tue Aug 01, 2006 4:35 pm
A general reminder to folks to please note the above rules.
Simple things like oversized images and signatures keep getting forgotton.
Heres the relevant bits, in bold for clarity:
Thanks for your understanding.
BJ
BlakJak
Postby Santa'sBoostinSleigh » Fri Jan 23, 2009 2:52 pm
this also means you cant have 6 lines of text PLUS a 100px high image...
think about it this way, your signature could be 3 lines PLUS a 50px high image and so on (basically reduce your image height by 16-17px per line of text)
and a line of text is counted as 'normal' font size...
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
