Turboing silvertop 4age?
Postby trueno_20v » Sun Oct 02, 2005 6:55 pm
Been thinking bout turboing my ae101 trueno silvertop 4age so need a bit of help on what i would need and how much its gonna cost. I can get a 600x300x70-80mm front mount new off trademe for around $250-$300 so thats sweet.
So where can i get a turbo manifold from?, also what sort of turbo i should use? Can i use standard ecu and AFM? What injectors? Fuel pump, and IC piping? Also what sorta boost it would handle reliably with standard internals done 155km, help would be good, cheers
ADMIN EDIT: signature too large
trueno_20v
Postby Alex B » Sun Oct 02, 2005 6:55 pm
Godammit can no one search these forums :!: :!: :evil:
Postby trueno_20v » Sun Oct 02, 2005 6:58 pm
Tryed, cant find anything
trueno_20v
Postby crnkin » Sun Oct 02, 2005 7:57 pm
same principles apply to silvertop as the 16v's
same crank, has oil squirters, has goodish rods, pistons can pose problems over 1bar.
However, with a link, t25 or t3/4, turbo manifold from grotty customs, animal customs, nite parts, evil_si, the list goes on... 440cc injectors and standard internals on about 10 psi you should be running a good 150kw atw, which would be good fun, if you wanna go over that youll either need race gas (nzefi runs 177kw atw on 18psi, racegas) or upgrade the pistons
other than that keep searching, it a massive topic i know!
deaf_homo "currrently yes"
crnkin
Postby trueno_20v » Sun Oct 02, 2005 8:02 pm
Sweet, can i use factory ecu? also what about fuel pump?
trueno_20v
Postby matt dunn » Sun Oct 02, 2005 8:31 pm
trueno_20v wrote:Sweet, can i use factory ecu?
No.
trueno_20v wrote: also what about fuel pump?
Yes
Postby trueno_20v » Sun Oct 02, 2005 9:41 pm
Why what happens if you turbo it with the factory ecu?
trueno_20v
Postby strap-on » Sun Oct 02, 2005 9:49 pm
i have heard third hand that it works with the factory ecu but only with a very small turbo on very low boost, the restriction on the exahust would outweigh any benifits and its mainly for the noise,
yourequire a new ece cos all the fuel maps will need to be changed
strap-on
Postby trueno_20v » Sun Oct 02, 2005 10:01 pm
Would a safc be enough to tune it with it on say 8-10psi?
trueno_20v
Postby Caveman » Sun Oct 02, 2005 10:17 pm
You could richen your afm output but it would run like a dog.
Your best bet is a 4AGZE. Then all you need is the manifold, turbo+downpipe and bov (cheap factory one) plus you can sell your old 20V to cover some cost.
Caveman
Postby trueno_20v » Sun Oct 02, 2005 10:39 pm
Yea tru but i want it 20v guess i could put 20v head on 4agze block but dnt want to do to much mucking around if its not all gonna be worth it.
trueno_20v
Postby Malcolm » Sun Oct 02, 2005 10:43 pm
problem with factory NA ecu's on boosted applications is timing.
you need to retard ignition timing with boost in order to prevent detonation. If you want a half reliable set-up you need some form of timing adjustment (or possibly a 4agze ecu but we wont go into that).
some people have got over the problem by running stupidly retarded base timing (like 0 degrees BTDC instead of 8 or 10 degrees BTDC), but this is far from ideal and will severely effect off-boost performance.
also one of those intercoolers is stupidly large for the power you will be seeing without some more major mods. Even one of the smaller 450x300x75 would be overkill.
Still, those 600x300 ones fill the bumper nicely and look good, which is all that most care about...
Postby trueno_20v » Mon Oct 03, 2005 7:48 pm
im thinking about buying a gtst turbo(t3), where abouts could i get a water feed for the turbo from?
trueno_20v
Postby crnkin » Mon Oct 03, 2005 8:00 pm
t3 is ok, but probly a little big and a bit of a hassle if your just on stock ecu, and if your after market its probly too small, go for a t28/5, m10, or a tdo4, for stock turbo, no intercooler or maybe a gze/rx7/vr4, and aftermarket- a t25 or t3/4 hybrid, with again a small intercooler.
If you do run a t3, water lines from enzed will do the trick
crnkin
Postby trueno_20v » Mon Oct 03, 2005 8:03 pm
crnkin wrote:If you do run a t3, water lines from enzed will do the trick
so where abouts on the motor/radiator can i get the water feed from?
trueno_20v
Postby JamesM » Mon Oct 03, 2005 8:46 pm
t3 off the skyline is not too big. t28 is bigger (cable of more power)
water lines are not essential. possibly tap into your water feed and return for heater if u want water lines.
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
Postby Caveman » Mon Oct 03, 2005 9:11 pm
td04 are a good option. Cheap and good boost response with a smallish intercooler. VR-4 sized intercooler are perfect size and can be had at $100.
If you want a 20V turbo prepare to dish out the dollars. I've explorered the route of turboing a N/A but its just too much hassel and too unreliable.
Caveman
Postby crnkin » Mon Oct 03, 2005 9:52 pm
ae-86_lad wrote:t3 off the skyline is not too big. t28 is bigger (cable of more power)
opps my bad
crnkin
Postby strap-on » Mon Oct 03, 2005 10:03 pm
unless your prepared to pay through the roof for custom fabrication and tuning there isnt too much advantage to keeping it as a 20v turbo and if you were gonna spend that amount of money you may as well take it to speedtech to get them to do it, i looked into it once with my 20v and decided it wasnt worth the effort
strap-on
Postby FYADUP » Tue Oct 04, 2005 7:18 pm
hey man if u want a turbo mani for a /4age you can buy mine off me, its off a map sensored GZE, u'll just need to get a new head flange lazer cut to fit ur 20v hole pattern. was for a td05, and has an external wastegate adaptor pipe. if u interested PM me.
Jason
R.I.P - 90 4AGTE GT-i Corolla Hatch [ROLYOU]
New 91' Corolla GT-i project! WATCH THIS SPACE
FYADUP
Users browsing this forum: Bing [Bot] and 14 guests
