Bearings... I need bearings.
All the Frequently Asked Questions which are of a technical bent. Look here before posting a tech query.
Postby RomanV » Tue Nov 08, 2005 9:09 pm
I need new bottom end bearings for my 3SGE. (Crank + rods)
My question is.... Is there a set of standard sized bearings that I buy, or do I need to check clearances etc?
I doubt I have the tools required to check anything this accurately, a set of digital calipers is the most accurate measuring tool I have.
The engine had nothing wrong with the bottom end when it was stripped down, and the crank is still the standard size.
Lynn was saying I should be able to get the part numbers for the bearings from the bottom of the block, and the crank?
Thanks for any Help.
Roman
Postby Mr Revhead » Tue Nov 08, 2005 9:51 pm
not the part numbers...
but the sizes
the crank and block has number on it
by using the toyota chart u get the size you need.
another way is order a set and rezie journals or caps to suit.
how about some TRD bearings? :wink:
Postby RomanV » Tue Nov 08, 2005 10:43 pm
Come on guys. :roll:
I wouldnt really be interested in TRD bearings anyway, whats the point?
Surely standard bearings would suffice.
I'll just go check the block & crank now, see if I can see any numbers of interest.
Postby Mr Revhead » Tue Nov 08, 2005 10:44 pm
yep stock ones wil be fine.....
but iirc TRD is actually cheaper.....
Postby RomanV » Tue Nov 08, 2005 11:01 pm
Mr Revhead wrote:but iirc TRD is actually cheaper.....
Yeah thats what I said, I want TRD bearings. :lol:
But seriously... What kind of numbers would I be looking for?
There is an '1100' stamped onto the crank, and there is some writing on it with white pen which I cant really see properly...
On the block, there is a figure 8 stamped inside the block near where the crank goes, like this:
Or am I on the completely wrong track?
Postby fivebob » Wed Nov 09, 2005 12:03 am
The following is for the 3S-GTE but should be the same as the 3S-GE.
Rod bearing mark #'s can be found on the old bearings or on the Rod Cap.
Main Bearing mark #'s need a bit more work if you don't have the old bearings. Ignore the bearing # in the following table as it doesn't make sense. Add the crankshaft and block #'s together to get the bearing #
Postby RomanV » Wed Nov 09, 2005 12:22 am
Aaaah, Legend. 8)
Im starting to think I should write 'Thanks again for the good info Fivebob' in my signature, it will save me some time. :P
acl race bearings
Postby Celica RA45 » Wed Nov 09, 2005 12:24 am
acl now make a race bearing for the 3sge so try these but other than that you could try King bearings and cdc make them as well but you need a copper lead base hope this helps
Celica RA45
Postby RomanV » Wed Nov 09, 2005 12:26 am
Aaah, okay.
Regardless of who/where I get the bearings from, does the numbering system supplied by Fivebob still apply?
I would imagine so.
I'll more than likely just use Toyota bearings anyway.
bearings
Postby Celica RA45 » Wed Nov 09, 2005 12:31 am
no only toyota make select fit bearings the others dont
Celica RA45
Postby Mr Revhead » Wed Nov 09, 2005 11:02 am
yep fivebob has the right stuff there.....
there is a little more, like a size chart for the mains i can fax you if you want.
the numbering sustem applies only to toyota bearings. ppl like ACL make one size fits all.
personally i think the best way is to measure the crank and block, then work out what bearings you need to give you the desired clearance
Return to Technical FAQs - General
