Ako wrote:Sweet. Much difference - core engine wise - between the ST165, 185, and 205 engines?
Just trying to find all this out BEFORE I start calling round wreckers etc.
geishaboy wrote:I want a number plate with "geisha" on it
But I should probably get a car first
Low_Aa63 wrote:as i am led to beleive any 4wd mounted 3stgte has had the factory mounting holes for the enginge mounts on the inlet side ground off from factory.
this is what i was told and also reaserched from various sites on the net when i was undertaking my 3sgte project!!
fivebob wrote:Low_Aa63 wrote:as i am led to beleive any 4wd mounted 3stgte has had the factory mounting holes for the enginge mounts on the inlet side ground off from factory.
Pardon my ignorance, but what engine mounts are on the intake side?
Low_Aa63 wrote:fivebob wrote:Low_Aa63 wrote:as i am led to beleive any 4wd mounted 3stgte has had the factory mounting holes for the enginge mounts on the inlet side ground off from factory.
The ones attatched to the block, you cant use a gt4 3sgte in rwd or mr2 without making a plate for the engine mout to bolt to then bolt the plate to different locater holes on the block as the origanal has been ground of from factory.
Low_Aa63 wrote:you cant use a gt4 3sgte in rwd or mr2 without making a plate for the engine mout to bolt to then bolt the plate to different locater holes on the block as the origanal has been ground of from factory.
Low_Aa63 wrote:are you not paying attention...i said "that is what i have found on the internet and such" sheesh
