slammed hilux utes
slammed hilux utes
Postby fangsport » Tue Jan 03, 2006 10:55 pm
a mate has a '92 YN81 sigle cab that he wants to do a number to.
what model 4wd guards/bumper/grille etc does he need to fit some big wheels under it??
has any got any contacts for the dropped front spindles? there was a shop in Auckland doing them, but they never returned any e-mails.
fangsport
Postby KE20 » Wed Jan 04, 2006 10:07 am
there was a guy on trademe selling drop spindles.i bought mine from usa. the 4x4 guards from the same year/shape should fit it. another way insteed of drop spindles, is to put a spacer block under the top ball joint. unbolt the ball joint on thr top swing arm andmove it to ontop and then put a block between it with loner bolts. they sell kits like that in usa for hilux's, instead if drop spindles from about '96 up, but ive compared a 2000 model with my 1988 model andthey both look the same.
Garage Dori
KE20
Postby fangsport » Wed Jan 04, 2006 10:27 am
KE20 wrote:there was a guy on trademe selling drop spindles.i bought mine from usa. the 4x4 guards from the same year/shape should fit it. another way insteed of drop spindles, is to put a spacer block under the top ball joint. unbolt the ball joint on thr top swing arm andmove it to ontop and then put a block between it with loner bolts. they sell kits like that in usa for hilux's, instead if drop spindles from about '96 up, but ive compared a 2000 model with my 1988 model andthey both look the same.
when you say spacer, is that a bit like a roll centre adjuster/correcter but on the top mount??
fangsport
Postby Mr Revhead » Wed Jan 04, 2006 10:40 am
a 2000 year model will be different form an 88
ones IFS for starters!
ln106/7 guards etc will fit, but also cost.
be very careful as some will try and sell you taiwanese panels.. and most of those are of shocking quality
Postby KE20 » Wed Jan 04, 2006 10:56 am
yip. but you only space the top.if you space bottom arm it screws up the steering. by putting the spacer at the top it allows the hub to move up higher(which lowers the ute more), and you dont have to change the bump stops, unless you want to go even lower.
i have dumby fitted my 2" beltech to mine, and 17" wheels just fit, with drop spindles you have to fit bigger wheels.
Garage Dori
KE20
Postby KE20 » Wed Jan 04, 2006 10:58 am
i am talking about RWD, a RWD '88 looks the same as a RWD 2000 model. i parked mine next to my work one, and compared them torison bars, swing arms all look the same. toyota probaly changed stuff like the tierods and ball joints being different sizes or sumthing, but generally they look the same, same set up.
Garage Dori
KE20
Postby Mr Revhead » Wed Jan 04, 2006 11:03 am
oh ok i got ya.
yeah some of the 2wd models didnt change as much as the 4wds
ln85s were still made in late 99.
yeah same basic set up
Postby fangsport » Wed Jan 04, 2006 11:09 am
Mr Revhead wrote:ln106/7 guards etc will fit, but also cost.
what is you price, Revhead? or do i need to e-mail?
fangsport
Postby Mr Revhead » Wed Jan 04, 2006 11:11 am
yeah best to email, then i can sit down and work it out
Postby KE20 » Wed Jan 04, 2006 11:14 am
Garage Dori
KE20
Postby fangsport » Wed Jan 04, 2006 11:22 am
cheers, it is as i had imagined it. so you make the block thickness to suit the amount of drop?
fangsport
Postby KE20 » Wed Jan 04, 2006 11:27 am
i quess so, but dont go to thick cause it might cause the hub to swing funny, cause your bringing the arms(at the hub) closer together. make up some dumby blocks and unbolt torsion bar, and fit blocks and swing hub up and down to work out how thick you can go before it swings funny or parts start to bind.
Garage Dori
KE20
Postby bluemaumau » Wed Jan 04, 2006 12:05 pm
tony @ slammed kustoms in whenuapai. dont have his number but you can find it 8)
my m8 went through him to drop his navara onto the ground 8)
Drop Spindles
Postby Randyroo » Sun Jan 08, 2006 6:59 pm
Go 2 www.forbiddenkustoms.co.nz They can supply them for $550 a pair.
Randyroo
Users browsing this forum: No registered users and 30 guests
