Tell tail signs of a small port redtop 4AGE
Postby Stealer Of Souls » Thu Jan 26, 2006 4:31 pm
Hi everyone.
What's the best way to determine if the engine in a car is a small port red top (versus a big port).
I've found an 88 AE92, the owner has had to replace the engine and thinks it may have been from a newer AE92.
If the big port has been replaced with a small port. How can I tell?
'86 AE85.5 Levin
Stealer Of Souls
Postby sergei » Thu Jan 26, 2006 4:35 pm
count the runners on intake manifolds (tube thingies), sarkplug leads are covered by plastic cover, the intake manifold does not has TVIS writing on it, instead it has small ribs on top, on the back of the head, gearbox side you will see a tube going from head to block...
Postby craigt » Thu Jan 26, 2006 8:58 pm
Also measure the injector spacing, smallport is equal spacing, largeport
has a much larger spacing between no 2 and 3
If it doesn't fit, force it.
If it breaks it needed replacing anyway!
AE101 4AGZE
KP60 4AGTE project
craigt
Postby matt dunn » Thu Jan 26, 2006 11:37 pm
sergei wrote:, on the back of the head, gearbox side you will see a tube going from head to block...
Thats the best way.
Hard to miss if it's there,
hard to make it look like it's there if it's not,.
Matt
Postby Stealer Of Souls » Fri Jan 27, 2006 8:58 am
Cheers guys.
Thanks for the help.
'86 AE85.5 Levin
Stealer Of Souls
