Changing hubs from drums to disks
Postby MrOizo » Sun Feb 19, 2006 10:22 pm
Whats involved in doing this?
i have an AE91 sedan which has the drum rears. I have also just bought some rear hubs (complete with disks, calipers, hoses and handbrake cables) off of trade me from a AE92 FXGT...
I have AE92 struts already in it and wanna move away from the drum rears.
Can i simply swap over the hub assemblies or is there more to it? master can stay the same? etc etc
thanks.
MrOizo
Toyspeed Legend
Postby Mr Revhead » Sun Feb 19, 2006 11:00 pm
brake porportioning valve will need changing to the disc set up
Postby MrOizo » Sun Feb 19, 2006 11:22 pm
is that in the master at all?
MrOizo
Toyspeed Legend
Postby Mr Revhead » Sun Feb 19, 2006 11:24 pm
nope, on the fire wall.
follow the steel lines from thw master, they will go into a block with 3-4 lines coming out of it. that should be it
Postby MrOizo » Sun Feb 19, 2006 11:30 pm
ahhh yipyipipy cheers,,,
adjusts the brake bias and all thatr... never knew the proper name for it :)
could it be as easy as getting one from a AE92 equipped with disks on the rear?
if so i'll have to have a look at pinch a part tomorrow :)
MrOizo
Toyspeed Legend
