Before you ask a question...
Postby Dell'Orto » Mon Feb 20, 2006 1:47 pm
Make sure you have a search beforehand, you'd be surprised at what has been covered in the past two years worth of posts in here.
If you're having some difficulty narrowing down the search field, please refer here: viewtopic.php?t=42026
Keywords are all important! 3SGTE cams will bring up very different results to 3SGTE AND cams :D
Brad
Postby Emperor » Mon Feb 20, 2006 1:51 pm
* Another small tip, if you're looking for certain stuff, such as 2nd hand wheels, springs, exhaust prices, use common sense and ring around places, you'll get a faster reply than posting on here.
Emperor
Postby Malcolm » Mon Feb 20, 2006 4:35 pm
and another tip, if you have questions about legalities of things, regarding certification or warrant of fitness, try the following websites for answers straight from the horses mouth:
www.ltsa.govt.nz
www.lvvta.org.nz
or talk to your local vehicle testing agent or LVVTA certifier (there is a list on the website)
Asking here will mostly bring up speculation and B.S.
Postby BlakJak » Fri May 05, 2006 1:06 am
Finally, make sure you check out the FAQ forum:
viewforum.php?f=24
Lots of useful bits and bobs there.
BlakJak
Postby MrOizo » Mon Aug 07, 2006 4:43 pm
Might as well add something to this list and you might have already seen it - who cares tho :)
Conversion calculator - pretty basic but usefull for converting things like:
:arrow: MPH <--> KMPH
:arrow: HP <--> KW
:arrow: PS (Metric) <--> KW
:arrow: NM <--> lb/ft
MrOizo
Toyspeed Legend
