Cool, Yeah I meant just get rust out, by whatever means. where can I pick that fish stuff from?no_8wire wrote:you can sand out rust? I normally just attack it with grinder...then fisholine on the bare metal and 3 days later paint/ start to bog...just normal car bog...
Rick wrote:The best and only real method of stoping rust is to remove it completely by cutting and welding in a new pannel but if that is not possible like in alot of cases then I would recommend Por 15, great stuff.
http://www.por15.com/
sergei wrote:Rick wrote:The best and only real method of stoping rust is to remove it completely by cutting and welding in a new pannel but if that is not possible like in alot of cases then I would recommend Por 15, great stuff.
Where can you get that stuff?
