Blacktops when cold
Blacktops when cold
Postby dotdog » Thu May 04, 2006 7:25 pm
Hey all, my BZR levin seems to hesitate alot when its cold, it sorta revs to about 2.5k and then it almost feels like its missing, Is this pritty common? any way to fix it?
Daily Ride - 00 Subaru WRX STi RA 12.7@113
Project Car- 89 Toyota Starlet Turbo S 95.1kws
Ex Ride - 85 Toyota Starlet Si with 4efte, 1990 Nissan Pulsar GTiR 150Kw/atw, 97 Toyota Levin BZR
My Profile: http://toyspeed.blakjak.net/profiles/profile.php?id=589
dotdog
Postby Rick » Thu May 04, 2006 7:34 pm
This happens to my mates blacktop no solution yet I think its quite common, where as my blacktop doesnt hesitate when its cold but it has a missfire which which I cant fix just about replaced everything on the dam thing.
Postby slammed_integral » Thu May 04, 2006 7:38 pm
could possibly be a earthing issue, go round tightening up all the grounding points. expecially by the intake manifold, injector area
http://www.cardomain.com/id/slick_ep
there is nothing sour cola worms cant fix...
slammed_integral
Postby dotdog » Thu May 04, 2006 7:41 pm
mine has only started doing it in the last 5000kms
dotdog
Postby matt dunn » Thu May 04, 2006 8:44 pm
Apparantly fitting a catch can fixes it.
Mine does it but have not got around to fitting one yet to see if it does work.
Matt
Postby dotdog » Thu May 04, 2006 8:59 pm
Ill try taking the breather out of the intake pipe then and ram it in to a coke bottle and see if that works
dotdog
Postby Miss_Trueno » Thu May 04, 2006 9:21 pm
My blacktop does the same, hesistation when cold as does my friends. Never did figure out the problem...
Miss Trueno - now piloting the Flying Baked Bean KP Starlet!
Miss_Trueno
Postby Rick » Fri May 05, 2006 12:28 am
matt dunn wrote:Apparantly fitting a catch can fixes it.
That has been tried but it didnt do anything to fix the hesistation.
Postby dotdog » Fri May 05, 2006 7:52 am
Cool, seems like a pritty common problem anyway, someone must of firgured it out LOL
dotdog
Postby Lanius » Fri May 05, 2006 10:44 am
Yeh I've noticed the same on my blacktop. When cold / still warming up, it seems to have a pretty bad flat spot just below 3.5 to 4k rpm. Once warmed up, she goes fine (have got a catch can fitted). The engine was very thoroughly serviced (everything short of a rebuild) before being installed, so I don't know if its anything that basic maintenance can fix (such as cleaning throttle bodies etc).
Lanius
Postby rallymazda » Fri May 05, 2006 11:02 am
mine does it as well
maybe a computer controlled thing so you dont thrash it when its cold????
[4AGE8U] << my old number plate
Got me a new altezza, now arrived
1991 corolla wagon- work hack
rallymazda
Postby Lanius » Fri May 05, 2006 11:33 am
Guess we need to hear from someone running a blacktop with an aftermarket ECU :P From memory, the Sard ECUs were aimed more at silvertops than blacktops (I stand to be corrected however), so not sure if anyone on TS is using one with a Blacktop ... ?
Lanius
Postby overkill » Fri May 05, 2006 1:25 pm
i have no real exp with blacktops, but, are the vvti systems oil pressure dependent?
coz pressure/volume of oil would be lower when colder. whether or not this affects an oil pressure sender/switch (or even a faulty one) + vvti at low rpm im not sure..
just a thought. sorry if that sounded stupid.
current:
ST162 GT-R, Daihatsu Mira R
previous :
AE92 Trueno APEX-limited 20v
AE82 GT Sedan (*sniff*)
ST182 GT-R, AE82 , AE82 GT sedan 20v
KE70 DX sedan, KE70 DX Wagon x 2
GA70 GT, N/A JZA80
overkill
Postby TrouserFxGt » Fri May 05, 2006 1:28 pm
I would imagine that it has some thing to do with the computer not activating the vvt until there is a certain engine coolant temp.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby overkill » Fri May 05, 2006 1:33 pm
TrouserFxGt wrote:I would imagine that it has some thing to do with the computer not activating the vvt until there is a certain engine coolant temp.
yea but
dotdog wrote:mine has only started doing it in the last 5000kms
current:
previous :
GA70 GT, N/A JZA80
overkill
Postby sergei » Fri May 05, 2006 3:16 pm
In case of Lanius' 20v, the inlet was clean when we fitted the engine, and I'm sure I've checked the throttle position sensor. BTW black top throttle position sensor does not have wire for IDL switch, so it makes easy to set it properly, wich is just setting it to 0.5v.
The only thing I can think off getting upset after a time is the thottle position sensor. And maybe oxygen sensor, but gathering from what people said the hesitation also occures at WOT, so oxygen sensor should not affect that.
I had hesitation problems with my silvertop, it happend on light to medium throttle in 3-4krpm area, also on slow transition from full to closed throttle. It was fixed after replacing ignition coil. At night I could see corona inside it, also I could hear discharge sound coming from it, but the car was driving fine apart from flat spot.. I suspect that spark was weak under high chamber pressure (which I assume is the highest in that rpm range, due to the engine being most efficient there).
Postby AceSniper » Fri May 05, 2006 7:06 pm
im using a sard ecu with silvertop loom on a blacktop... no problems, but I do have a pcv catch an TB's are clean
AceSniper
Postby matt dunn » Sun May 07, 2006 7:01 pm
overkill wrote:coz pressure/volume of oil would be lower when colder.
No, oil pressure is higher when cold as the oil is thicker.
Postby vvega » Sun May 07, 2006 7:10 pm
id be going the lead/plugs/cap/rotor/coil/ignitor path
typically you have higher cylander pressures when your engine is cold
so is a little harder on your ignition system
v
vvega
Postby matt dunn » Sun May 07, 2006 7:18 pm
vvega wrote:id be going the lead/plugs/cap/rotor/coil/ignitor path
v
I have the same issue with mine but have not looked into it basically because I dont drive it that much and I dont have the time at to track it down as it only does it when cold so you dont get much of a chance.
My symptoms make me believe it's none of those.
My symptoms just feel like someone someone pulls the handbrake 1/2 on for that rev range when cold.
Not a miss or anything.
Is that the same symptoms you others are getting?
Matt
