crnkin wrote:Yes but you didnt answer the question. I had the same problem on my mates wrx. We reset the ecu by disconnecting the battery for a few minutes then hooked it back up. I hate AFM.try it
slighty_sykotic wrote:I would say you somehow stuffed it up and the bov isnt sealing at idle/cruise.
So when you not under boost the bov is allowing air into the system that isnt being measured by the afm, causing it to run lean as hell and stall/die/cough.
Common on bov's that are vented to atmo AFTER the afm.
--Sykotic
EDIT:
Or prehaps your bov is stuffed? and when its plumbed in it doesnt matter if it's leaking cause of where its drawing air from (in relation to the afm).
--Sykotic
EDIT:
fivebob wrote:slighty_sykotic wrote:I would say you somehow stuffed it up and the bov isnt sealing at idle/cruise.
--Sykotic
EDIT:
No, his bypass valve is functioning correctly and allowing air to bypass the turbo when the manifold is under vacuum. That's the way the stock valve works.
It's not designed to be vented to atmosphere so don't do it, if you must have that phssst sound then fit an aftermarket BOV or better still an ARC cold air box.
solitaire wrote:OK... so just so i know what im talking about.... the stock ecu on a gen 1 cant handle it being vented to atmosphere? i know the stock bov can handle it because its currently doing it on a gen 3 mr2.... and the gen 2 bov off that gen 3 mr2 is currently on my car operating fine venting back into the intake as per factory... (they both appear identical... )
In summary the only way to do it with the stock bov on a gen 1 is an aftermarket ecu that can handle the air being vented to atmos rather than back in?
fivebob wrote:solitaire wrote:OK... so just so i know what im talking about.... the stock ecu on a gen 1 cant handle it being vented to atmosphere? i know the stock bov can handle it because its currently doing it on a gen 3 mr2.... and the gen 2 bov off that gen 3 mr2 is currently on my car operating fine venting back into the intake as per factory... (they both appear identical... )
The ECU can't handle the unmetered air at idle, just because it works on a Gen III doesn't mean it's working properly. There is still unfiltered air being sucked through the bypass valve (note I called it a bypass valve, not a blow off valve)In summary the only way to do it with the stock bov on a gen 1 is an aftermarket ecu that can handle the air being vented to atmos rather than back in?
Nope, while that would work it would still have unfiltered air entering the system. The only sensible way to have the phsssst sound with the stock BOV is by using an ARC cold air box, though with the AFM it's still muffled so adding a MAP based aftermarket ECU would be required to get that full boy racer effect.
FST4RD wrote:If you want to go cheap on the factory BOV you could do what I done in the past and my friend is using now.
I went to a gas fitting place and got a one way spring operated gas valve, it's the same diameter of the end of the BOV, got a piece of hose that fitted the end of the BOV and went on to the end of the valve, then blocked up the plumb back part of the cycle and there you go.
Cost me $20 for the valve and bout $2-3 for the hose, sounds awsome!!!
And it works a treat to, my friends car was running upwards of 18psi and it was fine (and if anyones heard bens turbo GTZ "blow off" you know what i mean by an awsome sound)
