ae101 amp installation
Postby Shads » Wed Aug 30, 2006 11:19 pm
Just currently trying to install an amp to run my front components in an ae101. After having a search on here / trying to locate and failing (go figure) the gromitt in the inside of the firewall to run the power cable for the amp through im kinda lost as to where it resides (seen a couple of different holes but none seem to the the right ones/ never realised how little space an engine bay has 0_o). Any help/photos would be greatly appreciated. :)
Save it for the Strip
Shads
Postby Snoozin » Thu Aug 31, 2006 12:00 am
Get a 13mm drill bit, associated grommet, drill a hole and go from there. I've always found it the easiest way, you don't interfere with anything else and you can run it where you want it.
Snoozin
Postby BigDon » Fri Sep 01, 2006 9:12 pm
There should be a grommit or hole inside the guard on the passengers side one going into/out of the engine bay (just behind the strut tower) and one going from the inside guard into the cabin and coming out down in the kick panel or above it.
www.europeandirect.co.nz
1996 AE111 BZ-G: TRD equipped road legal Club Car (Manfeild 1.25s) (SOLD)
1995 AE111 BZ-G: Stereo and daily driver (SOLD)
2005 NZ New Evo 9 GT (specd to FQ360) daily driver
2012 NZ New Outlander VRX - V6 family wagon
BigDon
Postby Emperor » Fri Sep 01, 2006 9:15 pm
Run it under the car!!! :lol:
Emperor
Postby DeeCee » Fri Sep 01, 2006 9:18 pm
BigDon wrote:There should be a grommit or hole inside the guard on the passengers side one going into/out of the engine bay (just behind the strut tower) and one going from the inside guard into the cabin and coming out down in the kick panel or above it.
this is what i have found as well..
some give emperor a light slap on the head for being the unsafe one...
GT Four Adovansu
DeeCee
Postby Alex B » Fri Sep 01, 2006 9:24 pm
Yeah, imagine running dangerious things like wireing/fuel lines/brake lines under a car :)
Postby sergei » Fri Sep 01, 2006 10:20 pm
well, from factory you get fuel and brake lines under the car ;)
Postby Alex B » Fri Sep 01, 2006 10:21 pm
Its called sarcasm :wink:
Postby sergei » Fri Sep 01, 2006 10:22 pm
I know, I've just added my sarcasm just in case you were serious ;)
Postby Bling » Sat Sep 02, 2006 1:14 am
I guess, u might lose brakes, or maybe lose your fuel supply..... if hit an object under the car....
but if you happen to earth ya power supply to the bottom of the car by bottoming out.... i'd be rather worried! 8O
Postby Alex B » Sat Sep 02, 2006 2:06 am
Hence the fusing at the battery. I think id rather bust a fuse than loose my breaks. Deecee is right tho, as you can just about garentee someone would not do it correctly.
Postby Snoozin » Sat Sep 02, 2006 10:12 am
I must be the only butcher who drills holes to get wires through :lol:
Snoozin
Postby RevolutionStarlet89 » Sun Nov 26, 2006 3:09 pm
Yeh i did mine that way, wouldnt say it was an easy process, but what way is easy??? :)
SKoty
Current Current Ride: 1992 Toyota Trueno Gt Apex
Ex-Current Ride: 1991 Toyota Levin Gt Apex(Written Off)
Previous Ride: 1989 Toyota Starlet XL
RevolutionStarlet89
Postby Jazza » Sun Nov 26, 2006 4:05 pm
I drilled holes for mine. Couldnt fit any of the wiring through the current holes.
1996 Curren - On Tardme
Jazza
Postby ThundaChild » Sun Nov 26, 2006 4:45 pm
Running all cables through there own grommeted holes is wise.
Use the correct grommet size for the cables and fuse correctly is a must as many a fresh install has gone up in flames due to careless behaviour.
There is an annoying amount of mucking round doing a propper install for power and RCA to speakers and amps and H/U but patience is a virtue with sound gear as a better result is always had.
If you need any more advise get hold of me I will help give you the correct info.
ThundaChild
Postby CozmoNz » Wed Nov 29, 2006 1:10 pm
You should really put something like "Anything I say is scarastic unless otherwise stated" in your sig alex...
Rayne For President!
CozmoNz
Postby thaphatty » Wed Nov 29, 2006 3:21 pm
just poke it out the side of the bonnet and put it past your door. you dont need to run a fuse either :lol:
JOKES GUYSH
thaphatty
Postby sergei » Wed Nov 29, 2006 3:56 pm
This so old that I don't remember posting in this thread 8O
Postby DeeCee » Wed Nov 29, 2006 5:33 pm
sergei wrote:This so old that I don't remember posting in this thread 8O
i thought you were a russian spambot peddling english language lessons??
GT Four Adovansu
DeeCee
Postby sergei » Wed Nov 29, 2006 6:32 pm
I'm not a bot, I'm human, and I preffer corned beef (cold) on the bread.
