4age starter motor compatibility
Postby l1ttle_d3vil » Thu Nov 30, 2006 6:55 pm
after much searching everywhere, I cant find any solid information...
apparently 4agze starter motors are not compatible with rwd gearboxes...
so if im running a 4agze in a rwd setup with a w55, what sort of starter motor will I need? will the one fitted to my standard bluetop engine/flywheel work? or are the teeth going to be different...
cheers.
Postby Rick » Thu Nov 30, 2006 7:37 pm
I am running a 4agze in a rwd setup with a w55 and I am using a starter motor from a n/a smallport, the solenoid/heat sheild comes close the exhaust headers. An ae86 starter motor is larger in size and has the solenoid underneath but is not as grunty as the small port starter motor.
Postby l1ttle_d3vil » Thu Nov 30, 2006 10:06 pm
this will be with a turbo though, so the distance between the starter and exhaust manifold wont really matter.
is the only difference really just the grunt of the starter, and the physical size of it? with the bolt holes and gears being the same?
Postby crnkin » Thu Nov 30, 2006 10:28 pm
yep all 4age/ze ones will bolt up and have same pinion
deaf_homo "currrently yes"
crnkin
Postby johntramp » Fri Dec 01, 2006 12:23 am
the 20v starter motors are different tho
johntramp
Postby thaphatty » Fri Dec 01, 2006 8:51 am
I use one off a MS65? (I think) crown to a 20v and its quite a chunky big mother
thaphatty
Postby matt dunn » Mon Dec 04, 2006 8:27 pm
crnkin wrote:yep all 4age/ze ones will bolt up and have same pinion
not quite,
AW11 GZE may suit the NA versions, but the AE92 and AE101 GZE ones are definatly different mounting spacings between the holes.
Matt
Postby l1ttle_d3vil » Mon Dec 04, 2006 9:58 pm
sweet as, i got a couple of starters here. both 16v n/a ones, aslong as one of them fit the aw11 4agze then it'll be sweet. one of them may actually be a smallport one too so all good :lol:
cheers for the info.
Postby Vertigo » Tue Dec 05, 2006 12:02 am
what about 2A starters? do they fit on bigport's?
TVIS just kicked in, yo!
Vertigo
Postby jormos90 » Mon Dec 18, 2006 9:36 am
Just finished conversion of 4AG-20V into DX...
After starting I think i could hear gear whine, so finished exhaust and shure enough the starter stayed engaged...
After removing it and checking measurements I appears that the starter I have is to close to the flywheel or vice versa.
Engine: 4AG-20V silver
Gearbox: AE85 K50
Flywheel: unknown origin but it fits...
Starter: unknown origin, it was marked with 3A/4AG in twink...
Anyone had this issue?
KE70 4AG-20V, KE70 3SGE BEAMS
jormos90
