The engine had close to 200,000 ks on it when we pulled it from the ae101 and ive probably put about 3000 or so on it since.
For the swap, we (myself and 84vvt from the mr2 club) used the standard ECU, and mated the engine wiring harness to the mr2 body harness and for the most part it works pretty well.
The problems im having, are listed below.
- No pull. Its very smooth and only really feels any stronger above 5000 or so - is this normal? Initially we thought this might be a cause of the very restricted exhaust we had on it, however we have freed it up yesterday and performance hasnt increased. Noise however, has.
- runs rich - when you boot it to redline (when its warm, i drive it under 4000 when cold) browney smoggy smoke pours out of the exhaust - especially in 1st and 2nd. I understand the 20vs generally run rich, but i cant imagine a car from the showroom floor doing this!
- not sure if vvt is engaging (possibly the cause of no pull?!) i intend to do the solenoid test in the next few nights. is the vvt solenoid a wear item?
- reverse idle up - when its cold, it idles between 900 and 1000, as it warms up, it moves to 1500/1600 and sometimes 1800.
- dropping oil, i suspect the cam cover gasket as its all over the belts.
to try and sort these out i have:
double checked vacuum hoses for leaks
replaced spark plugs
replaced fuel filter
complete oil change
double checked sensors are plugged in
replaced exhaust (now running silvertop headers to lengthened 2-1 pipe into 2.5" mild steel piping into a resonator into a high flow muffler)
I dunno, maybe i should just buy a blacktop head and bolt that to it, probably cheaper
