and this is.............
Postby bluemaumau » Wed Feb 28, 2007 7:33 pm
so........
:roll:
help is appreciated.
cheers :)
Postby bluemaumau » Wed Feb 28, 2007 7:43 pm
the 2 larger lines run from below the t/b. the samll line "t's" off a line from the waxstat thingy.
its off a ae92 afm gtz btw
Postby Barks » Wed Feb 28, 2007 8:04 pm
I had the same question last year. As far as we could figure out it's an idle mixture adjust valve....
"Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music"
Kristian Wilson, Nintendo, Inc, 1989
Latest rides: 2004 Avensis Wagon, GT Avalanche 1.0, GT Avalanche 0.5, Marin Toscana CX
Barks
Postby bluemaumau » Wed Feb 28, 2007 8:07 pm
hmm interesting...... do you have a link to the thread?
Postby 2LTR Rona » Wed Feb 28, 2007 9:14 pm
its not a Fuel Pulsation Damper is it ? (quickly flicked through the 1989 MR2 Manual)
bluemaumau - is it on the fuel line before before the pressure regulator ?? (was a bit hard to tell from those pics)
If you like I can burn the whole manual to CD & post to you, just PM me details
2002 Altezza, 1974 KE25
2LTR Rona
Postby bluemaumau » Wed Feb 28, 2007 9:20 pm
bluemaumau wrote:the 2 larger lines run from below the t/b.
the small line "t's" off a line from the waxstat thingy.
it doesnt have any direct fuel lines altho if memory serves me correct the small line tees off another line which runs from inlet->waxstat->blue vsv->abv.
edit:its the blue vsv
Postby Barks » Wed Feb 28, 2007 9:50 pm
The fuel pulsator dampener is the thing that bolts onto the gearbox end of the fuel rail. There isn't a thread about the valves, it was more a case of my uncle and I sitting down and tying to figure out what the hell it actually was, and yeah, adjustable idle blah blah blah......
Then of course we may be completely wrong! :P
Barks
Postby sergei » Thu Mar 01, 2007 12:08 am
It is AC Idle Up valve with adjustment.
Postby bluemaumau » Thu Mar 01, 2007 8:28 am
thank you sergei!
so next question......
can i just plug all 3 lines since i dont have aircon?
Postby sergei » Thu Mar 01, 2007 9:38 am
Yep. In fact you can get rid of whole valve/solenoid mumbo-jumbo and plug the hoses at the source (don't do a U one into another, if you do, put ballbearing inside the hose so it blocks the flow, just use big enough so it will not go into inlet).
