W55/W57 gearboxes.
W55/W57 gearboxes.
Postby matt dunn » Wed Apr 11, 2007 8:52 pm
After some info and identification of some of these gearboxes.
I want to order some gearbox parts from Toyota but need chassis numbers from some cars to make sure I get the right parts.
I run a gearbox with a shifter location the same as this pic.
http://www.trademe.co.nz/Trade-Me-Motor ... 442065.htm
I want a chassis number of a car that comes with a w55/w56/w57 etc etc with the shifter in this position
so i can order a part from it.
Also want the chassis number of a car that has W57 on the chassis tag,
so i can order some parts specific to those ratio's.
Thanks
Matt
Postby KinLoud » Thu Apr 12, 2007 8:24 am
I think I have that position W55 Matt. It is still in the car at the moment.
Once it is out I will confirm the position and post the build plate...
Do you have a measurement from front of box (not bell) to centre of shifter hole? Just to avoid hassles.
Ken
Ham
021 408 863
Postby thegreatestben » Thu Apr 12, 2007 8:47 am
I'll have a look at the position of my w55 and grab a pic of the ID plate tonight.
thegreatestben
Postby Mr Revhead » Thu Apr 12, 2007 1:04 pm
looks like a gx81 turbo has the right box.
8)
Postby thegreatestben » Thu Apr 12, 2007 7:42 pm
So have you got it sorted?
I have the pics of my cresta box and tags etc...
thegreatestben
Postby matt dunn » Thu Apr 12, 2007 8:55 pm
tgb.mr2 wrote:So have you got it sorted?
not yet,
If you could email me a pic of the box and the tag etc etc would be great.
rachmat@xtra.co.nz
Thanks
matt
Postby overcast » Sat Apr 14, 2007 6:50 pm
overcast
Postby matt dunn » Sun Apr 15, 2007 12:44 pm
overcast wrote:http://users.tpg.com.au/users/loats/technical/ma61/gearboxes.html
possibly some help
already have that link,
but there is no chassis numbers etc etc to order the parts from.
Postby thegreatestben » Sun Apr 15, 2007 7:18 pm
Hope these are of some use
thegreatestben
Postby matt dunn » Sun Apr 15, 2007 10:15 pm
tgb.mr2 wrote:Hope these are of some use
cool thanks
Postby AE25 » Fri Apr 20, 2007 12:50 am
ive seen a few jdm gx61 with the mid/rear shifter position like in pic.
my '85 'nz new' ma61 celica/supra has factory w57 in it.. with front shifter position. ma61's usually have w58 in them so it may be the 'nz new' ones that got the 57? hope that helps
the 4 common positions...
front
Image ta63 + tt142 GT-T 3tgte w55, ma61?
mid
Image CE71 wagon W51 or W56
mid-rear
Image 80's cressida's
rear
Image *a70 supra
the easy way to remember which position is which by looking at what angle the shifter housing slopes up from the end of the alloy tailhousing (where metal output shaft shroud fits onto)
front = angle forward
mid = straight up
mid/rear = angle rearward
rear = horizontally rearward
E2 & E7 fanatic
http://www.toycrazy.net
AE25
Postby method » Fri Apr 20, 2007 1:21 am
AE25 wrote:ive seen a few jdm gx61 with the mid/rear shifter position like in pic.
front
mid
mid-rear
rear
Image later model large sedans?
Shit that post is GOLD.
Couldnt find a good set of comparison pics anywhere, looked high and low for ages!
Should be put in FAQ!
PICS UPDATED DAILY
method
Postby Mr Revhead » Fri Apr 20, 2007 10:00 am
agreed, done 8)
if anyone has other info, or seem good threads let me know
Postby thegreatestben » Fri Apr 20, 2007 10:50 am
AE25 wrote:
rear
My GX81 uses mid rear position.
The w58 out of a GA70 has that position so I'd Say *A70's and maybe *A60's would be rear shifter
thegreatestben
Postby KinLoud » Wed May 02, 2007 6:00 pm
I added a pic of the shifter and buildplate of the gx61 I parted. Might help you Matt
viewtopic.php?t=57191&start=0&postdays=0&postorder=asc&highlight=shifter
Ken
Ham
021 408 863
