ae86 digi to analogue dash wiring q's whos done it ?
Postby AE85.6 » Wed Apr 25, 2007 3:23 pm
just checking who has done this as i have a couple issues,
first of all do both plugs for the cluster have to run an earth or just one ?
the blue light for high beam is on constant with ignition on or off.
oil pressure gauge does not work so far which i assume is because i need a different oil pressure switch ?
If you drink, and drift,
your a bloody lunatic
AE85.6
Re: ae86 digi to analogue dash wiring q's whos done it ?
Postby big_boy » Thu Apr 26, 2007 12:11 am
AE85.6 wrote:first of all do both plugs for the cluster have to run an earth or just one ?
both should have secapart earths from memory
AE85.6 wrote:the blue light for high beam is on constant with ignition on or off.
it draws its earth switched signal from the high low beem switch & has constance +12v
AE85.6 wrote:oil pressure gauge does not work so far which i assume is because i need a different oil pressure switch ?
yes there different to go from switch/warning light to gauge
for sale EE90
big_boy
Postby AE85.6 » Thu Apr 26, 2007 11:18 pm
cheers pm sent
AE85.6
Postby AE85.6 » Sun Apr 29, 2007 7:58 pm
dont spose anyone has a wiring diagram for the dash cluster
AE85.6
Postby matt dunn » Mon Apr 30, 2007 9:56 pm
AE85.6 wrote:dont spose anyone has a wiring diagram for the dash cluster
I did as I did one at work, may still have the diagrams,
also, AE86 has oil gauge analogue, and light on digital,
and the fuel senders had to be swapped over aswell, and I think the speedo drives were different calibration too.
We went from digi to analogue.
You realise that when the high beam is turned on,
The way it is wired from factory on toyota's it tells you when the low beam is turned off.
will look for the diagram at work tomorrow.
Postby AE85.6 » Tue May 01, 2007 9:05 pm
pm sent mr dunn
high beam indicator sorted.
AE85.6
Postby big_boy » Wed May 02, 2007 10:16 am
matt dunn wrote:and the fuel senders had to be swapped over aswell
only on the early ones from my finding we were expecting to do this but then found the later ones to be the same for both
the difference is in the early gauge type all eletric & later gauge are the same
matt dunn wrote:I think the speedo drives were different calibration too.
this depends on witch diff you have
altho i think you need the white plastic bit that holds the drive to the dash form your dash you want to use. or zip ties :P
for sale EE90
big_boy
Postby AE85.6 » Mon May 21, 2007 10:24 pm
just waiting for fuel sender to arrive then swap this and the oil sender which will sort those gauges.
however engine check light and overheat light are not going yet,
anyone know which wires and pins on the plugs are relevant for these ?
AE85.6
Postby matt dunn » Wed May 23, 2007 11:54 pm
Ok not a diagram but a list.
Was going to email it too you but post it on here so all can see.
I think part of it may be missing but it's all I have.
A list of pin numbers, function and some colours.
Some interpreting may be required,
Digital Dash
1 Dash Illumination (g)
2 handbrake light (r/b)
3 cat converter light ®
4 oil light ( y/b)
5 charge light (b/o)
6 lights light (y)
7 right indicator (g/y)
8 earth for illumination (w/b)
9 hi beam light (r/g)
10 left indicator (g/b)
11 Tail light check ®
12 door light (r/g)
13 door light (r/w)
14 engine check (g/r)
Analogue NZ New dash
1 Dash Illumination (b)
2 Dash Illumination (g)
3 Gauges earth (br)
4 Temp Sensor (y/g)
5 Blank
6 Oil sender (y/b)
7 Engine Check (g/r)
8 Blank
9 Hi beam light
10 Earth (w/b)
11 charge light (y)
12 charge light (b/o)
13 ign Rev (b)
14 Ign power (r/bl)
15 Blank
16 blank
17 blank
18 blank
19 speedo earth (b)
20 fuel light (y/b)
21 door light (r/w)
22 speed sensor (b/w)
23 door light (r/g)
24 blank
25 handbrake light (r/b)
26 fuel sender (y/r)
27 Right Indicator (g/y)
28 Left indicator (g/b)
Matt
Postby AE85.6 » Fri May 25, 2007 6:04 pm
awesome cheers matt,
ummm sorry to be a pain but #9 ?
AE85.6
Postby matt dunn » Fri May 25, 2007 8:39 pm
AE85.6 wrote:awesome cheers matt,
Typo fixed.
